Results 1 to 9 of 9
Thread: Aftermarket Light Mounts
    Registered User slime's Avatar
    Apr 2017
    US129, Louisville,Tennessee
    What's everyone doing for driving light mounts? I don't have engine guards on my R850R, but would rather have them higher up. I no longer have access to a machine shop while I'm unemployed. Not much room around the fork legs with the fairing, unless I put them low. I have a set of Ridgid lights, but they flat mount.
    Ride fast, take chances.
    Sep 2006
    CENTEX USA
    You say 850R but mention fairing in way of fork mounts?
    Have seen them mounted to underside of outboard oil coolers.
    Have a set that clamp around the turn signal stalks on a 1100R but no clue who made them.
    Have a set of these on my GSA, it sure if still available but the website is up with a 2007 date on bottom
    http://www.lumalink.com/lumalink_brackets.html
    The advantage to lowering them is the triangle provided for approaching vehicles. Up close to headlight, they just make a larger single profile... my .02 cents
    Sep 2006
    CENTEX USA
    These were from about 1999 purchase, so no clue if still available
    Phone number only, pre dot.com!
    Apr 2017
    Thanks. The only issue with down low mounts is they don't light up down the road. I want some smaller ones down low for that. My fairing is a Parabellum Scout, so it mounts to the headlight mounts and the handlebar mounts. Not really an option..sadly.
    Sep 2006
    CENTEX USA
    Like this?
    Are lights light enough to mount to fairing?
    Have seen lights on top of oil coolers as well
    Registered User jnrugg's Avatar
    Sep 2007
    Danielson, Ct.
    https://www.summitracing.com/search/...mount-brackets
    There are car and bike mounts one of which may work.
    Apr 2017
    Like this?
    Yes
    Apr 2017
    Quote Originally Posted by jnrugg View Post
    Thanks. I forgot about my car places. There's just not a lot of room with the fairing. I found some that may work, but after measuring my front forks the lowers are not round..they are oval. Still may work. A hair over 2.0 outside of on lower to the outside. Front to back 1.84 inches. That's around the top of the fender.
    Aug 2018
    Fargo, ND
    There are a ton of choices for light mounts on Amazon. Many are made to fit a round tube with different rubber inserts for different sized tubing.
    From the only real Fargo, ND!
  1. Aux light mounts
    By 71243 in forum Oilheads
    Last Post: 09-08-2017, 03:23 AM
  2. Aux. light mounts R11RS
    By Ken F in forum Oilheads
    Last Post: 03-14-2012, 01:39 AM
  3. Auxillary light mounts on your RT
    By Brian-NC in forum Hexheads/Camheads
    Last Post: 02-01-2012, 09:33 PM
  4. 96 K11RS light mounts
    By TONUP in forum Flying Brick K-bikes
    Last Post: 12-20-2007, 08:38 PM
  5. R1200RT AUX. Light Mounts
    By HankPfister in forum Oilheads
    Last Post: 02-16-2006, 02:30 PM
