r0ckrat
Active member
Greetings All. I read the entire 4 pages and think I have the answer but will ask...I have new to me 2020 R1250RT with D-ESA etc.. Previous was 2007 R1200RT with manual everything and upgraded shocks/springs so you already see a technical challenge. My problem: cannot change out of MAX dampening. After reading, it appears that I keep trying to change with throttle open & riding...this is the problem. I tried changing in the garage, ignition on, motor off...still stays on MAX.
- Do I need to have motor running?
- Or, change dampening on the fly by clutching, zero throttle, straight up coasting no matter the speed?
- Use the wonder wheel to select Road or Dynamic and then spin the wheel again to MIN, MAX, AUTO?
- Missing anything?
I have a 2016 R, so the settings are a little different, but I think you have to be either sitting still with the motor running, or clutch in and throttle closed. So while riding you can select the desired setting, then pull the clutch and close the throttle for a few seconds, then continue on your merry way. I think.
