Results 1 to 14 of 14
Thread: Brake fluid reservoir pictures please
    Jan 2020
    Philly Suburbs, PA
    Hi. I took my F800GS for its first service last week. Finally Tonight I noticed that the reservoir seemed a little cloudy or milky. I remembered it being clear. Can someone take a picture of their reservoir for me? Should I be able to see through the reservoir or does the reservoir make the brake fluid appear cloudy.
    Iíll check it again in the sun light.
    Jan 2020
    Philly Suburbs, PA
    Cloudy after riding
    After riding the brake fluid looks cloudy gold. Before riding it is clear gold. Whatís going on with that.
    Registered User Guenther's Avatar
    Jan 2007
    Colorado Springs, CO
    When I picked up my F700GS after the 600 mile service the service manager pointed out that the rear brake fluid should be replaced...it was BLACK. I changed/flushed the fluid myself and it is still clear after 2 years.
    /Guenther
    2017 F700GS - I wish it had a drive shaft
    Lanark County near Ottawa ON
    The brake fluid in the rear reservoir on new F650/700/800 bikes is always black. It is just colour picked up from the hose. It does not affect the function just looks bad. After a fluid change or two all is normal. You used to be able to see black fluid on new bikes still in the showroom.
    Sent from my SM-T813 using Tapatalk
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Quote Originally Posted by RadioFlyer View Post
    Not always. Over time it tends to remain clear for longer periods. The rear fluid in Annie's 2014 GS now remains clear for well over a year. I see this same tendancy in the other F8GSs I maintain.
    Kevin Huddy
    Jan 2020
    Philly Suburbs, PA
    Taking it back in for service. Noticed the reservoir leaks on the side stand from lid. Also noticed fluid between reservoir and the base where it screwed in. Hopefully reservoir isnít cracked and the leak around base is only leak from lid. Does anyone know what the reservoir looks like on the bottom? Can you technically unscrew the reservoir and find it connected to a hose?
    Note that I said always in reference to NEW bikes. After my first two changes there has been no further discoloration.
    Jan 2020
    Philly Suburbs, PA
    Took it in today and the fluid looks clear. Dealer indicated they flushed the system, yet i am still getting some cascading in the resevoir when i press the brakes. Doesnt flushing mean they clear our brake lines too?
    Tech took off skid plate too, is this something that needs to be done when flushing brake system?
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by epirusgr View Post
    What do you mean by cascading?
    When they flush the system, fluid in the brakes lines is also replaced.
    Lee
    2016 R1200RS
    MOA # 30878
    Jan 2020
    Philly Suburbs, PA
    I guess my question is how do they flush on an f800gs. I didnít see the tech open the screw by the brake caliper, but rather took off skid plate.
    There is something in the reservoir that comes up when I press the brakes, contaminants? Old brake fluid? Guess we will find out in a few weeks or months.
    Do you need a GS911 to flush ABS brake fluid? Will the computer get an error code if you donít?
    May 2003
    SW Iowa
    Bleed screw on the calipers need to be opened and closed during a brake bleed.
    Not familiar with the F800GS so I'm only guessing the skid plate came off for the oil change.
    The GS911 will cycle the ABS pump and move fluid threw the pump.
    If a GS911 or shop computer is not used during a brake bleed it will not throw a error code.
    Lee
    2016 R1200RS
    MOA # 30878
    Jan 2020
    Philly Suburbs, PA
    the problem persists....
    Took it out on a 10 mile drive today and noticed droplets out of the resevoir. Not sure this is residual from they filled it up, or if it once again leaking or overtightened. Thoughts?IMG_8430.jpegIMG_8431.jpeg
    Jul 2007
    Big Sky Country
    Over filled.... rubber boot/seal is misaligned... there is a carck in the reservoir... there is a flaw on the lip of the reservoir... the cap is cross threaded on the reservoir.... excess fluid on the reservoir threads when the cap was reinstalled.... you are continually doing stoppies. Not hard to check for all of these possibilities, but if you do not wish to do it yourself then take it to a dealer. If possible to a different dealer.
    Kevin Huddy
    Jan 2020
    Philly Suburbs, PA
    Thank you. This dealership is unbelievable. They told me to open the resevoir and remove some brake fluid and dry off seal. So i did that and now i am having the same cloudy crap floaring in the resevoir again. This tech definately never flushed the system. I dont even see tool markings on the bleeder valves. He simply emptied the resevoir and refilled it.
  1. 03 R1150R rear brake fluid reservoir location?
    By pacemaker in forum Oilheads
    Last Post: 07-23-2018, 11:40 PM
  2. Clutch and Brake Fluid Reservoir Cap Removal
    By BC1100S in forum Wedge K-bikes
    Last Post: 09-15-2017, 04:16 AM
  3. Brake fluid reservoir cap paint peeling
    By bikenut595 in forum Hexheads/Camheads
    Last Post: 11-20-2015, 04:36 AM
  4. Replies: 6
    Last Post: 07-27-2014, 09:25 PM
  5. 1994 K75S ABS I Rear Brake Fluid Reservoir
    By Slipster in forum Flying Brick K-bikes
    Last Post: 03-02-2014, 09:29 PM
