Results 1 to 6 of 6
Thread: /5 thrust bearing servicing
    Registered User ebeeby's Avatar
    McKinney, Texas
    Anyone have some links to servicing the thrust bearing? Video perhaps? Haven't been in there in a long time and can't remember if I can pull the actuating rod out and still get it back in without removing gearbox.
    1973 R75/5
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    If you are doing the thrust bearing, you can do it without pulling the transmission. If you intend to remove the pushrod for the clutch, then you will be better off removing the trans. But for just the thrust bearing you would disengage the clutch cable, remove the clutch arm pivot and then the arm, then remove all the parts of the thrust bearing. A small magnet often comes in handy for that. Not a difficult job, just a little finicky (technical term).
    F.O.G.Rider, Rounder #6,
    Ambassador, WI Airmarshal
    BMWRA Wisconsin Region Rep
    Please: what do you mean by thrust bearing. I am aware of two that position the crankshaft fore and aft in the engine case. I don't think you mean these by interpreting the conversation. Do you mean the clutch "throw out" bearing, or what?
    McKinney, Texas
    Thanks. If I recall correctly, there is just a felt pad and the bearing to extract?
    1973 R75/5
    Liaison 20774's Avatar
    Part #4 here, called "bearing ball cage" on the fiche, later years called the "needle cage":
    https://www.realoem.com/bmw/enUS/sho...diagId=21_0071
    #3 and higher can be removed from the rear. Don't try and take the felt off the rod...that's best done when the transmission is removed.
    McKinney, Texas
    It had been so long I had forgotten that the rod tip sticking out is part of the piston (once the lever assembly is removed). Futzed (Deutsch for "dicked") around for a while before realizing I could just pull on that rod tip to extract the piston and that I was not pulling the actual actuator rod rearward. After that, the bearing and then the "reinforcement" disc came out easily with a magnet. Whoever was last in there put the grooved side of the "reinforcement" disc forward and the smooth side against the bearing. This could be the noise I was hearing though why it took me 15+ years to hear it is beyond me.
    In any case the bearing was in fine condition -and wet as it should be - which is what I really wanted to check. Re-assembled correctly and tested - it's quiet but need to run up to op temp to see for sure.
    Those old micro-fiche are at times misleading and at others confusing. Ah well, alls well that ends well.
    1973 R75/5
  1. Crank thrust washer
    By melter in forum Airheads
    Last Post: 06-26-2016, 02:37 PM
  2. R1150XX - Clutch Slave Thrust Bearing
    By David.G.Millington@gmail.com in forum Oilheads
    Last Post: 05-29-2010, 09:05 PM
  3. Brake Thrust Washer Replacement
    By RoscoeRules in forum Hexheads/Camheads
    Last Post: 07-14-2009, 11:37 PM
  4. 74 90/6 transmission thrust pin boss
    By NOMARSHALL in forum Airheads
    Last Post: 04-27-2009, 05:30 PM
  5. Clutch thrust seal seepage
    By ebeeby in forum Airheads
    Last Post: 11-06-2006, 10:55 PM
