Results 1 to 15 of 16
Thread: storage of motorcycle in arizona summer
    I will be storing my R1250rt this summer in Arizona. Any issues with storing it in my enclosed garage where it will be exposed to the summer heat, or should I wheel it into my house where I will have the air conditioning set to around 90 degrees? Of course I will do the usual things such as gas stabilization, trickle charge the battery, etc.
    Quote Originally Posted by 98879 View Post
    I would put it in the house. Storage in an enclosed building may hit 160 or more degrees. The plastic parts won't like that.
    Registered User Moto316's Avatar
    Nov 2007
    Phoenix, AZ
    It would be better in the house, but it should be fine in the garage. The heat can have an effect on the rubber components, drying them out, so check those when you get back. Hopefully you do not have any critter problems in your garage where you live.
    Remember to put some 5 gallon buckets of water in your bathtubs, it helps to keep moisture in the house while you're gone.
    Quote Originally Posted by Moto316 View Post
    I think I will try to squeeze it in the house, will have to take the front door off of the hinges and then I think I can squeeze it in. Have about 3 or 4 five gallon buckets to put in the house and a neighbor will refill them and check on the house every 2-3 weeks.
    Nov 2007
    Phoenix, AZ
    160? Not likely. Of course, there are always individual circumstances to consider. Do you have any insulation in your garage walls? What direction does the garage face, a southern exposure will heat up faster than a northern exposure. I have lived in Phoenix for 20 years and my garage usually stays within 5 degrees, plus or minus of the ambient temperature. Today it is 95 degrees outside and inside my garage is 90 degrees.
    Sep 2009
    Cherry Hill, NJ
    98879 - If you do decide to keep the bike in your house, I think you should consider the insurance implications. Gasoline in the tank, leaking oil, possible home AC power loss, and the like. Your homeowners policy may have some details which could be helpful.
    John Gamel - BMW MOA Consumer Liaison 2018-Present
    2015 Ebony Metallic R1200RT
    MOA #153274
    "We have met the enemy and he is us." Pogo-via Walt Kelly
    Mansfield,MA
    A lot of expensive collector cars are kept at climate controlled structures. Out the direct sunlight is optimum and would be the biggest “threat” to prematurely aging a vehicle. IMO, anything past that is a nicety.
    All these machines have had “basic” protection since they left the factory and have done fine on their long journey and warehousing.
    Mod Squad
    2009 F800GS 1994 TW200
    We have a newly constructed house, garage is insulated and it has a northern exposure along the entire length, except for the ends which are facing east and west. It usually feels cooler in the garage than outside and we are out here now with highs in the low 100's the past 4-5 days. It's actually 90 inside garage now and 103 outside! With that said I'm tempted to leave it in the garage this summer. I didn't think of possible insurance issues if I kept it in the house. I suspect the majority of people who live year round in Arizona keep their motorcycles in non air conditioned garages?
    OK, I stand corrected. My "garage" is a one-car metal building and will heat up above ambient temperature quite a bit. But I would demur to those who actually live in Phoenix. The last time I was there it was 119 and not cool anywhere not air conditioned or under water.
    Aug 2018
    Fargo, ND
    I would leave it in the garage. The way you describe it I doubt it will ever get over 100F in the garage. Keep in mind the concrete slab is a pretty good heat sink and you would need to heat it up too. Far cry from Pete's tin shed. They can get like an oven if not insulated.
    Hey Pete, 120F in Phoenix isn't near as hot as 120F in southern Texas!
    From the only real Fargo, ND!
    Nov 2007
    Phoenix, AZ
    That is very similar to my house. I have always had a bike or three in the garage, never a problem from the heat. Batteries do not like the heat, but it sounds like you have that taken care of. Enjoy your summer somewhere cooler, I'm jealous!
    Will the battery survive in the garage on a trickle charger or should I pull the battery and put it in the house where it's cooler?
    Aug 2018
    Fargo, ND
    It wouldn't hurt to put the battery inside. 75F would be better than 90F.
    How long will you be gone? I would be tempted to clean up the battery, charge it, stuff it in a heavy plastic bag and put it in the refrigerator or freezer if you are leaving the fridge running. I know it sounds crazy, but a battery is a chemical reaction and anything you can do to slow it down helps. Cool and dry. If nothing else, bring it home and store it in the freezer!
    I'm 30 miles east of Phoenix. The garage is insulated. If yours is insulated like mine, it won't get much over 96 in the garage, even with several days above 114-115 in a row at times. My garage faces west, so the sun beats on the door all afternoon in the hottest part of the day [ which out here happens to be between 2:30-3:30 in the afternoon ].
    As long as I'd set it up for storage [ battery out and stored in cooler temps as someone mentioned ], I'd not give my bike another thought about being stored in my garage. YMMV
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    Quote Originally Posted by brownie0486 View Post
    Sounds good, thanks for the information everyone. Heading back to Wisconsin for summer coolness, but also have to get back to work!
  1. Hello from Arizona
    By labbats in forum New Members
    Last Post: 03-20-2015, 02:31 AM
  2. Arizona
    By cardno7 in forum Off the Beaten Path
    Last Post: 11-15-2011, 06:30 PM
  3. New guy from Arizona
    By Travis Bikel in forum New Members
    Last Post: 07-08-2011, 11:01 PM
  4. summer storage
    By ISAMEMON in forum Airheads
    Last Post: 04-21-2008, 02:13 AM
  5. Motorcycle Storage Idea
    By leboutillier in forum Ride Reports
    Last Post: 10-17-2007, 04:27 AM
