Results 1 to 15 of 15
Thread: C650GT Belt maintenance
    Hi guys,
    Im coming up on 15000 kms on my bike now (C650GT) and I've been reading snippits about how the CV belt should be changed or adjusted somehow at some point, some suggesting around this time. I am currently having no issues with the bike, no loss of power or anything, but have been warned that the belt could suddenly break if I don't do this? Im having a hard time believing that a BMW machine would need such a major job at only 15k. Does anyone know more about whether I should be concerned about this and plan for it? The belt alone can run me $700-900 here in Canada to get one to my door, then who knows how many thousand to have it all done. Makes me lean towards trading in the bike rather than go through all that expense at only 15-20k. Am I over-reacting?
    There seems to be very little info online or otherwise as to a maintenance schedule for this bike. I've changed the oil and filter at 10k and changed the front tire, but that's about it so far.
    Debbie's Servant Lee's Avatar
    SW Iowa
    When I look it up it shows replacing the belt and rollers every 20,000 km.
    Lee
    2016 R1200RS
    MOA # 30878
    So basically every 12K service. Interesting. Probably cheaper than replacing/repairing a final drive.
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    If you don't mind sharing, where did you look that up? I'd like to find a proper maintenance schedule for this bike
    Quote Originally Posted by brownie0486 View Post
    Expensive enough to replace belt and rollers, to replace the final drive you may as well just trade it in before that happens.
    SW Iowa
    Quote Originally Posted by richardus View Post
    If your talking to me, I looked up a Riders Manual.
    Service schedules are usually toward the back of the Riders Manual.
    The parts fiches shows $398 US for a belt . $598 Canadian??
    Rollers are $118 US.
    https://www.ascycles.com/bmw/2016/C6...tml#PartsTable
    Lee
    2016 R1200RS
    MOA # 30878
    So if this is the guideline, unless I run into any serious issues such as loss of power or heaven forbid the belt breaks, I should be good for at least another 5000 kms.
    The belt and rollers should only run me about $300-350 on ebay from Taiwan or China, and whatever labor for my bike shop to do it (I'm not skilled enough to do this myself)
    I could have the bike totally renewed for under $1000 which is a lot cheaper than trading it in.
    Prices are all over the place on Ebay but looks like I can get one for around $150 CAD, some have free shipping, from Taiwan or China.
    Rollers about $100 CAD and labour from the bike shop, depending how long this job takes them. Im hoping to do this for $1000 CAD when done.
    gig harborr ,wa
    On the F800 bikes with belts, replacement is at 40K. I have heard of some going as long as 60K. I would get a service & repair manual for that scooter. Also it should show you how to check the belt tension and rollers.
    SW Iowa
    Quote Originally Posted by EUGENE View Post
    On the F800 bikes with belts, replacement is at 40K. .
    40,000 miles?
    Lee
    2016 R1200RS
    MOA # 30878
    SW Iowa
    I would not be comfortable with buying a belt from China or Taiwan but that's your call.
    If you don't get any replies here from scooter owners about a good place to buy a belt other than BMW check on the Adventure Rider site.
    They have a active section for scooters. https://advrider.com/f/forums/battle-scooters.36/
    Ask them where's a good place to purchase a aftermarket belt.
    Lee
    2016 R1200RS
    MOA # 30878
    gig harborr ,wa
    40,000 miles?
    No, 40K is 24,000miles
    Registered User REDC650GT's Avatar
    Feb 2013
    Grand Prairie, TX
    PM schedules for C650 GT
    These were posted years ago when I had my 650 GT
    https://forums.bmwmoa.org/showthread...nance+schedule
    There is a belt out of Italy it is the real thing. I got mine with duty and taxes under 200 Canadian. And yes the belt will go on a long time and not break. It will damage your variators and you will need to replace them.
    If you look closely at the edge of a new belt there is a small flat at the top edge. As the belt wears this small flat will also, if it wears to far that the flat disappears then it will cut into the variators.
    The entire 650 drivetrain came from Taiwan (Kymco) so I wouldn't be too concerned about a getting a decent belt or rollers from there. Heat is hard on belts. Most scooter CVT belts are air-cooled, so keeping the filter clean to allow for cooling airflow is important.
    The BMW 650 scooter also uses a conventional chain for final drive and I believe nylon blocks maintain tension, sort of like an old Harley primary drive. There is a maintenance procedure to adjust or replace the chain routinely as well.
    -Live as fully as you can as long as you can-
  1. Considering a C650GT
    By engage in forum Scooters
    Last Post: 05-29-2019, 02:54 AM
  2. C650gt
    By 32232 in forum Scooters
    Last Post: 04-22-2013, 03:16 PM
  3. C650gt
    By 110593 in forum Motorrad
    Last Post: 11-02-2012, 02:44 PM
  4. c650GT when?
    By samuelh in forum Motorrad
    Last Post: 07-01-2012, 03:11 AM
  5. C650gt ??
    By 40427 in forum Rally Forum
    Last Post: 06-23-2012, 01:07 PM
