Results 1 to 4 of 4
Thread: 2000 k1200 LT right turn light not working
    Apr 2020
    Okeechobee , FL
    Question 2000 k1200 LT right turn light not working
    so my right turn signal indicator flashes once on the dash but the signal light isn't working correctly. any ideas please , thanks .
    lieghts
    it used to be light burnt out, or there were corrosion in there, check wiring
    Apr 2020
    Okeechobee , FL
    rt turn signal not working
    thank you for your reply , the socket was bad for 1 thing but I think there was a different issue, I couldn't find the issue but it started working again.
    Ground maybe?
    Often moving the wires reestablishes the ground and then the light works... its not always the power side of the equation that is the problem
  1. Replies: 25
    Last Post: 05-26-2013, 03:19 PM
  2. R50 1969 turn signals not working
    By 1der in forum Vintage
    Last Post: 09-02-2011, 03:44 AM
  3. 1150 GS turn signals not working
    By MAGOO in forum Oilheads
    Last Post: 08-12-2007, 12:18 AM
  4. Replies: 7
    Last Post: 09-06-2006, 02:08 PM
