Results 1 to 8 of 8
Thread: Brake light stays on
    TX Rider
    May 2006
    Richmond, KY
    Have a 2007 650 Dakar. Problem is that the brake light is on regardless of if I have the brakes applied or not. I assume that the front or rear brake switch is stuck in the brake position. I checked the rotation of the wheels and both turn easily so the brakes are not on. Any help here on how to fix?
    Mansfield,MA
    I think your bike is a single? I can move your question to the “Thumper” section later
    Anyway, the switches could be sticking as I would guess they are getting a bit long in the tooth as well. I would try WD-40 spray into the switches while working the pedal/lever while watching the light. I would do one at a time to help isolate the culprit. WD-40 is usually a help but not a long time cure.
    Good luck.
    Welcome to the forum!
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User Guenther's Avatar
    Colorado Springs, CO
    I would pull one wire out of the foot break switch. This way you can tell whether it's the front or the rear brake switch.
    /Guenther
    2017 F700GS - I wish it had a drive shaft
    TX Rider
    May 2006
    Richmond, KY
    Brake light
    Thanks...will try that, but the switch is really hard to get to.
    TX Rider
    May 2006
    Richmond, KY
    Brake light
    [QUOTE=Omega Man;1202922]I think your bike is a single? I can move your question to the “Thumper” section later
    Good luck.
    Sorry, I put this in the wrong forum. It of course is a single cylinder. I have tried a very thin military gun oil, but probably need something with a little solvency. Will give it a shot.
    D,
    TX Rider
    May 2006
    Richmond, KY
    Brake light stays on--2007 F650 Dakar
    Guys, my brake light stays on all the time. I assume it is either the front or back switch that is sticking, but wonder if others have had this problem and how did you fix it? Thanks.
    D.
    The wire from the rear brake light switch ends in a blue connector with a yellow and a green/black wire. Should be somewhere visible under the seat. Disconnect the blue connector and check the brake light.
    /Guenther
    Mansfield,MA
    Quote Originally Posted by dddoggett View Post
    D.
    Merged up the threads
    Mod Squad
  1. Brake light stays on all the time on my R90/6
    By rbryson in forum Airheads
    Last Post: 07-09-2012, 12:58 PM
  2. Brake light stays on
    By miairhead in forum Airheads
    Last Post: 09-02-2009, 02:18 AM
  3. abs flash and brake light stays on
    By rtbutch in forum Oilheads
    Last Post: 07-04-2009, 05:28 PM
  4. Brake Light Stays On
    By axlray13 in forum Airheads
    Last Post: 04-24-2009, 02:58 PM
  5. Brake light stays on
    Last Post: 04-20-2009, 08:52 PM
