tasslehawf
Ongoing project to get this bike to run.
I posted a video on reddit of it basically not turning over and starting fluid, but after I did the fuel injectors, I tried holding the throttle and it does run. It just dies if I let go of the throttle. https://www.reddit.com/r/Fixxit/comments/fqubm0/2006_r1200rt_starting_issues/
- Bought the bike in 2016 with 14k miles. Rode it fine until it stranded me on my way to work.
- Bike sat for almost a year due to an electrical problem that I thought was going to strand me (turned out to be a bad ignition switch).
- After I discovered this, I rode the bike for a couple months before I took the gas tank and body panels off to bypass the servo brakes over winter break (the rears had failed).
- I have replaced the fuel pump and basically the whole fuel pump assembly due to suspect rust (I now own 4 fuel pump controllers, one of which is brand new). I also tried replacing the battery.
- Based on suggestions from my previous post, I just cleaned the fuel injectors.
- The bike still won't turn over, but I found that I can hold the throttle and it will run, but dies as soon as I let it idle.
