Moshe did a review a while back. He writes for several leading moto magazines.[/video]
Chip seal is apparently about as tire friendly as a wood rasp or cheese grater.....The lovely country roads through the farm and wine country of western Oregon are all chip seal.
On the flip side traction should be better.....
With a smaller contact patch due to the "valleys" between the chips inherent in this type of roadway, the traction would be reduced as compared to smooth asphalt. The same reason slick tires provide more dry traction than treaded tires.
\On the flip side traction should be better ...
I have an old tire I would like to cut in two. Which side of my saw blade should I use? Smooth edge down or tooth edge down? Which would be the hardest to push with my old arthritic shoulder?
I absolutely disagree. Which grips rubber better: a smooth metal yardstick or a wood rasp?
I respect your opinion.
At the same time, why are drag strips smooth? And how soft would a tire needs to be for the road to be able to mechanically impress itself into the rubber itself?
Typical traction on pavement is achieved by the minute irregularities in the pavement - think grains of sand but not loose of course - pressing into the relatively softer rubber of the tire.
I think you're making my point for me. The minute irregularities are much more numerous in fine-grain asphalt than in coarse chip surfaces. I also get your point on drag racing surfaces. I was going to the extreme.
Tire comparisons are fun but I can mount three sets of same tire on same three models and the results are all over the map with one guy bragging and one in total meltdown.
See Post # 15, this thread
