Results 1 to 6 of 6
Thread: 77 r/100 partial headlight malfunction
    removed old fairing, installed new controls on left handlebar. Horn works, parking bulb works.
    Low beam not working, Hi beam not working except when thumbing down on switch
    Mansfield,MA
    This is more of an Airhead if I'm not mistaken.......I can move the thread for you?
    Mod Squad
    2009 F800GS 1994 TW200
    oops
    thanks.
    Liaison 20774's Avatar
    I've heard of this before, but can't really remember what the answer is. First, I'd check the resistance across the terminals of the bulb. I suppose you could also check the voltages you get to each of the wires that lead to the bulb...obviously, if you don't get 12v to the high and low beam wires, then the problem is not the bulb. Second, I would suspect the light relay.
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Check your installation
    I would carefully check where you have the wires for the new switch plugged in.
    Things are tight in the headlight, it is easy to get wires on the wrong terminal. St.
    thanks
    will do and check back in. Thanks
  1. R 1200 GS Headlight malfunction
    By jnerges in forum Hexheads/Camheads
    Last Post: 06-11-2020, 06:38 PM
  2. Partial display of home page
    By jaherbst in forum Forum Software Specific Help. NOT for bike related questions.
    Last Post: 07-17-2011, 02:02 AM
  3. Replies: 4
    Last Post: 08-26-2010, 04:08 PM
  4. ABS Modulator Malfunction?
    By COOLTOMCAT in forum Oilheads
    Last Post: 10-09-2008, 12:35 AM
  5. ECM malfunction
    By mayojuaf in forum Oilheads
    Last Post: 01-24-2007, 08:58 AM
