Results 1 to 7 of 7
Thread: Mystery plug
    Mystery plug
    Hello all you Wizards of Smart. Recently did a spline lube on a 1999 r1100rt for the first time and all seemed to have gone quite well until I discovered a mystery connector that had no plug in. It is near the airbox on the left side where the neutral and side stand wires connect. It looks like the connector that goes on the left throttle body. Three wires, 1 white, 1 brown and 1 green with a light yellow stripe and metal clip. See attachment. I do not remember this connector during disassembly.IMG_0166.jpg Any insights will be greatly appreciated. thanks, Gregory
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Looks identical to the connector for a CO Pot. My RT did not have the pot but I built mine from a basket case. Some other RT's that have come my way did have the pot but also the charcoal canister.
    It controls idle richness or lack there of and maybe yours doesn't need it? I put one in my bike, mostly because it was free, but with the tools I have I got my idle to 700 RPM which is what I want.
    If you didn't have one before and didn't have any issues, have a good day and get some riding in.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    The major civilizing force in the world is not religion, it is sex.
    Has, perchance, the charcoal canister and associated parts been removed from this bike. That looks like the connector for the valve that connected the two hoses from the throttle body to the single hose from the charcoal canister. It would have been located right about under your thigh on the left side of the motorcycle.
    Jun 2017
    Tucson, AZ
    I discovered the same plug on mine a month ago or so after doing a spline lube. The charcoal can was attached then but that is what I assumed it was for. Have since removed the canister.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    CO Pot connector
    Brown/yellow Pin 1
    White/black Pin 2
    Green/yellow Pin 3
    No CO pot needed as your vintage of bike has/uses the O2 sensor
    Ufda happens..........
    3 Plus Porn Plug
    This special 3 + sign connector - if connected to a 3 + Sign converter DVD cable to a TV will allow you to watch motorcycle Porn that is programmed into the RT's mind or ECM and Canbus...
    The movies are all bike related like Mein Hot Thang, I want Your Pipe.....to great ones like "Frankfurt and Fast Women on 1150's"...
    BMW riders in Germany use this plug a lot
    Need answers I got'em
    T
    TRedd
    DBLUPPR snookers's Avatar
    Jul 2010
    Niagara Wine Region
    Quote Originally Posted by GSRedd View Post
    T
    2000 R1100RT , 2005 K1200S w/hack
    Niagara BMW Riders #298 BMWMCO #45
    "The measure of a society is how it protects its most vulnerable members."
  1. Replies: 4
    Last Post: 08-05-2010, 03:29 PM
  2. mystery with my GS?
    By dramer in forum Oilheads
    Last Post: 03-07-2010, 08:03 PM
  3. 1200RT Mystery Plug ?
    By MotorRunning in forum Hexheads/Camheads
    Last Post: 12-21-2009, 11:53 PM
  4. mystery wiring plug (see pic) what is it?
    By DOINTHETON in forum Airheads
    Last Post: 03-05-2008, 07:37 AM
  5. Mystery Box? Help me ID it.
    By kitze2 in forum Oilheads
    Last Post: 12-30-2007, 04:52 PM
