Results 1 to 5 of 5
Thread: R1250RT Wish the top box LED brake light did more.
    Registered User cereed0419's Avatar
    Jan 2020
    Gainesville
    Hey guys.
    My top box LED light only functions as a brake light. My previous FJR had a Givi that had running lights, brake and blinker lights.
    Has anyone seen someone reconfigure the wiring to allow the integrated LED light bar to be more useful by at least having a running and brake light function? Or maybe I just have to buy auxiliary lights. Thanks, Craig
    Registered User kevinsclo's Avatar
    Sep 2013
    Toronto, Canada
    I forgo that option thinking the same thing. For that price, it ought to do more.
    Aug 2018
    Fargo, ND
    I have not looked into it, but have thought about re-pinning the electrical connector and moving the top case light wire to the same as the tail light. The top case light is an LED so I doubt the tiny extra load would be an issue. Worst that would happen in the ECM, or what ever BMW's fancy name for it is, won't like it and not function, so be sure to test it well. You will not burn anything up trying it.
    I pull a Unigo trailer and have changed the trailer bulbs to LED, then wired directly into the RT's wiring and it functions fine.
    From the only real Fargo, ND!
    Registered User cap's Avatar
    Oct 2016
    Fort Collins, CO
    Quote Originally Posted by cereed0419 View Post
    Hey guys.
    You might try reaching out to customer service at Skene. They sell a controller that patches in to the wiring harness and adds functionality to the brake lights. In particular, they have a unique "conspicuity flicker" solution that I like a lot. That might achieve what you want, using your existing tailcase lights.
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    Hey guys.
    I have clearwater lights on my 2016 RT, along with the billie jr brake light that mounts onto the license plate holder. I've wondered whether the wires that go to the billie jr could be used for the BMW top case instead to power the brake light, and control its brightness, etc...
    Personally I have the older style (Hexhead/Camhead) top case, so the brake light was not an option. I would mount my Billie Jr on that, but I only put the topcase on the bike when I really need it, so I'd have to add some sort of reliable quick disconnect for the wiring for the billie jr.
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
  1. Engine light on brand new R1250RT
    By cereed0419 in forum Wetheads
    Last Post: 01-29-2020, 01:36 AM
  2. Replies: 6
    Last Post: 08-02-2019, 11:05 PM
  3. Adding LED light to Brake/Tail light on 2011 R1200r
    By tonyd48 in forum Hexheads/Camheads
    Last Post: 10-31-2014, 01:59 AM
  4. Replies: 2
    Last Post: 01-06-2007, 09:26 PM
  5. K100RS Brake Light, Warning light and Switch headache
    By sgtbill in forum Flying Brick K-bikes
    Last Post: 11-19-2006, 09:32 PM
