Airbox cleaning - parts question
thomhplatt
Hey guys! Due to this nasty COVID-19 stuff I got a laid off my job... that means I have 2 months to get deep into the R90/6 and give her some well needed love... she’s been sitting for 21 years. Yikes.
Anyhow... I’m in the Airbox and I want to know if the cross bar/bracket with 1 central bolt is safe to remove, or if it’s supporting something below it?
Ill post a pic to show you what I mean!
Stay safe and thank you for the replies to this thread, as well as the other countless posts. It’s all very helpful.
Thanks!
This picture shows the "clamping spring" in question:
https://www.realoem.com/bmw/enUS/sh...76_2477_BMW_R_60_7&diagId=13_0480#13721251169
The bolt holding it is only 22mm long. Not sure what it screws into...guess it's a steel screw threaded into the aluminum transmission case. Doesn't look like it connects to anything inside the transmission. There is one or two bolts somewhere that I thought it was suggested to not remove. Duane has something mid way down on this page.
https://w6rec.com/bmw-motorcycle-5-transmission-gearbox-service-and-repair/
If it were me, I'd loosen the bolt, move the clip out of the way to clean, and then move back into position. I just don't trust what might or might not be on the other end of that bolt.
You can take that bolt out with nothing falling off on the inside; but it you are cleaning with any kind of fluid then putting the bolt back in will prevent fluids from getting inside.
