Results 1 to 5 of 5
Thread: 2012 G650GS transmission question
    Last summer we bought a 2012 G650GS for my daughter for her first bike. Has about 40K on it and we are third owner. She loves it and it is a great bike --but for one thing. I'm not sure if it is a problem or if "they all do that": When shifted into first from neutral, the whole bike lurches quite noticeably, as if the clutch is not fully disengaged. Does this cold or hot. Once in gear, shifts smoothly, with no missed shifts or false neutrals. Clutch seems to function OK and adjustment is correct per the manual.
    My three previous boxers (airhead, hexed, camhead) did not do this.
    Do we have a transmission problem? I'd appreciate feedback from another G650GS owner or technician?
    Chris Ossanna
    Quote Originally Posted by 34560 View Post
    Chris Ossanna
    It is not a transmission issue. At worst it is a clutch issue. It strongly suggests that the pulling of the clutch lever is not allowing/causing the clutch to completely disengage. You should try reducing the free play at the lever which will slightly increase the amount of cable pull on the clutch. This will minimize if not solve the problem. But do make sure there is still some free play.
    That said, there is a little bit of "they all do that" with the F650 single and G650 bikes. All three of ours would do it if the weather was cold. You can combat this by being sure to always hold the front brake firmly when shifting a stationary bike from neutral or second into first.
    Chris Ossanna
    As Paul replied, most “wet clutch” bikes will do this to some extent, but excessive drag may indicate warped clutch plates. Even so, most riders just live with it. Clutch packs are fairly easy to replace but parts can be expensive.
    -Live as fully as you can as long as you can-
    Smile Thanks Paul!
    Thanks Paul: Your technical knowledge of BMWs is unsurpassed!
    --Chris
    Cool Thanks!
    Quote Originally Posted by OldCamper View Post
    Thankyou. This is a load off my mind. Now I can just worry about everyday stuff, like Covid-19.
    --Chris
  1. LED Installations on 2012 G650GS?
    By kantuckid in forum Thumpers - F & G bikes
    Last Post: 06-24-2013, 07:18 PM
  2. Cases for 2012 BMW G650GS
    By kantuckid in forum Gear
    Last Post: 05-30-2013, 07:52 PM
  3. 2012 G650GS oil change
    By kgadley01 in forum Thumpers - F & G bikes
    Last Post: 12-28-2012, 03:37 PM
