Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: throttle cable mod
  1. #16
    There certainly were reported problems, surging being key among them. That said, Voni's R1100RS at over 400K miles has never exhibited any issues with the cable other than synching the throttle bodies each major service. I actually like that much more than I liked the bell crank system on my R1150R. But that is just me. I was used to futzing with Airheads and this was a lot less futzing than that.
    My point was that if a person is bound and determined to eliminate the factory splitter then going to the older single cable might be preferable to transplanting a kludge of Airhead parts. Of course, having never done that I might be wrong.
    Paul does Voniís RS still has the original throttled cable?
    1999 Triumph Tiger, 1998 K1200RS, & 1994 R1100RS
  2. #17
    Quote Originally Posted by roninbuffalo View Post
    No. Number 2. The original was replaced at 283,695 miles.
  3. #18
    Jul 2004
    Charlottesville, VA
    Quote Originally Posted by brianfisk View Post
    way easier to change cables ( no slitter involved
    ) and no gain or loss with adjustment
    So, what components would you use? Cables, throttle assembly? Anything else?
    Anton Largiader 72724
    Tech articles - YouTube
  4. #19
    Registered User brianfisk's Avatar
    Cromwell CT
    This was just thoughts from my first encounter with the setup. With over 500,000 miles on 4 oilhead RTs it's getting tough to change cables, but don't see me doing it again unlees on the side of the road. So no scratching my head and trying to find the right parts
  5. #20
    Thanks Paul I have 84 k on my 94 RS I had a hell of time getting my throttle bodies sync. I thought it was cable but when I found the real issue and corrected it everything fell in place. I really like the single cable and at present time don't see any reason to change it.
  6. #21
    Jul 2004
    Charlottesville, VA
    This was just thoughts from my first encounter with the setup...
    OK, then the same question for anyone else who thinks this is practical. What parts would you actually use to improve on the existing late R1100 throttle cable system?
  7. #22
    Jan 2016
    Central Illinois
    What were issues why hard to sync?
  8. #23
    Quote Originally Posted by 179212 View Post
    I could not get the throttle bodies to work because of the butterfly shafts being lose put the Dan Cata(sp) kit in and everything fell in place.
  1. Replies: 4
    Last Post: 04-12-2019, 11:25 PM
  2. throttle cable
    By jaybird1150 in forum Airheads
    Last Post: 03-18-2014, 10:35 AM
  3. Throttle cable lube for sticky throttle
    By wzellwzell@yahoo.com in forum Gear
    Last Post: 12-09-2010, 06:16 AM
  4. Throttle Cable
    By Picinisco in forum Oilheads
    Last Post: 04-28-2010, 10:52 PM
  5. K75/2 throttle cable
    By cayuse60 in forum Flying Brick K-bikes
    Last Post: 03-19-2008, 02:27 AM
