Results 1 to 6 of 6
Thread: 1985 K100RS coolant capacity clarification.
    Jan 2020
    Calgary, Alberta, Canada
    The owners manual states 2.8 liters (3 quarts) with 0.4 liters in the equalizing tank. Clymer states 3.0 liters (3.2 quarts) and 0.4 liters in equalizing tank. The quarts are U.S. volumes. How much are you guys putting in these bikes?
    Quote Originally Posted by mcmlcccvrs View Post
    On my K75s I assume I will need at least three quarts. Then I add coolant and as I do so massage the hoses until I am confident the air is out. When the collant is up to the cap I then add to the midpoint in the expansion tank. It takes a bit less than 3 quarts but the block is smaller on a K75 than on a K100.
    Jan 2020
    Got it! Not so much a definitive measured amount necessarily.
    Thank you.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Thank you.
    Correct. Completely full at the radiator cap with no trapped air in the block (run the engine until the thermostat opens. Usually 7-10 minutes or until the fan kicks on). Then let it cool down and top off. Then fill overflow bottle midway between hot and cold.
    Before filling radiator, make SURE that there are NO cracks in the hose between the radiator fill neck and the overflow bottle. A crack in this hose will cause air to be sucked into the radiator and will cause overheating.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Jan 2020
    Pretty much what I did but only put in coolant volume as stated in manual. Squeezed the hoses and a few more bubbles came out and it took about another 300ml to bottom of neck. All brand new Samco hoses including overflow.
    Bluenoser
    Mar 2010
    Lethbridge Alberta
    Take the amounts in the Clymer manuals as a guide. Over the years I've found many cases where the amounts & measurements are wrong.
    1986 K100RT
  1. '85 K100RS Coolant in oil?
    By mcmlcccvrs in forum Flying Brick K-bikes
    Last Post: 03-08-2020, 07:04 AM
  2. 2009 K1200LT Coolant Capacity
    By blackbeemer in forum Flying Brick K-bikes
    Last Post: 07-28-2018, 04:10 PM
  3. 1991 K100RS fork oil type and capacity
    By littledog in forum Flying Brick K-bikes
    Last Post: 06-14-2015, 07:39 PM
  4. 1985 K100RS coolant filler cap
    Last Post: 05-21-2013, 11:47 PM
  5. Coolant Temp Gauge 1985 K100RS
    By walt3022 in forum Flying Brick K-bikes
    Last Post: 03-24-2013, 04:37 AM
