Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
Thread: Broken Tabs
  1. #31
    Quote Originally Posted by PoorUB View Post
    I spit on the pegs before I put the panel back on!
    I use grease.
  2. #32
    Old Rider - OK Mechanic 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    Gromets
    After the piece holding the grommet is reattached - before engaging whatever sticks in the grommet - reduce the diameter. I dislike the system of these "mushroom" things stuffed into those grommets even when the grommets are in a hole in a steel piece welded to the frame. So on my K75s and R1150 and others, I always sand down the male portion to make it smoother, smaller, and easier to insert and remove.
    I like to put a little silicone or dielectric grease on these grommets ease the slid in process. A very small electrical ties wrapped through the center of the grommet will keep the grommet in place.
    David Nicholls
    Teulon Manitoba - Canada
    2015 R1200GSA-LC
  1. 2003 K1200GT - What glue to repair tabs?
    By jrmull in forum Flying Brick K-bikes
    Last Post: 11-07-2019, 10:05 PM
  2. Front fender tabs
    By cschmidt in forum Wetheads
    Last Post: 05-08-2018, 12:04 AM
  3. Side cover tabs on R100RS
    By windancer in forum Airheads
    Last Post: 01-14-2013, 11:34 PM
  4. Replies: 6
    Last Post: 05-29-2009, 01:26 PM
  5. Corkscrewed centre stand tabs
    By TonysR100 in forum Airheads
    Last Post: 03-03-2009, 10:58 PM
