anotherbmw
As the title says. Long story short, my rotor was shot so I got the kit from EME, new rotor, stator, stator frame cover with brush holder and brushes, diode board, voltage regulator.
I installed everything, started the bike up and the charge light would not go off (not charging). I checked all my wires, connection, etc. and all seemed good. Battery is newish and charged at 12.8 V. I then went through the component testing as per EME's website, tested the voltage regulator by bridging the two ports (even tried with my old VR), measured the diode board to make sure I only get reads in one direction (passed), resistance between the two rotor rings (also good) and finally the stator. Everything seems fine. I have no idea what I could have done wrong. I also installed new ignition brakers and a new condensor, but the bike is running and that doesn't have any input on the charging (I think).
Probably what I really need now is some detailed instructions on what to measure where with the bike running, e.g. measure A/C output at the stator, DC at the breakers, diode board, something like that. I just don't know enough of this that would let me think this through. If anyone could give me some help here, I would truly appreciate it. I am beyond frustrated at this point, because I can't see anything that could be wrong.......Thanks!
