New to the group with my new to me 2015 K1600 GT. PO put on 71k and took excellent care of the beast as far as I can tell, w/ service records and the limited # of mi. I have ridden. Since I live in Mi., I have invested in a range of heated garments to extend my riding season. I hooked up the fused 12v wiring harness directly to the battery, as I have on my airhead, to run my coat, gloves, pants and heated insoles. Everything worked fine. My only gripe is a noticeable surging of the engine at idle. I did not delve further into what the voltage readout was because, quite frankly, at that time I had not learned how to control all the new bells and whistles. Now that I have a bit more understanding of the system, I also note that charging rate (no heated garments) going down the road is around 13.7v. I am under the impression that the AGM/gel type batteries should charge at a higher rate of 14.5 - 14.7 range. If this is the case, is there a way to adjust the charging voltage? Back to the surging; this is mostly annoying and a bit embarrassing in stop and go traffic, but not something I can't live with. Thanks for reading and I appreciate any suggestions.
Rodney
1984 R100
Original owner
2015 K1600 GT
(Welcome to the 21 century)
Rodney
1984 R100
Original owner
2015 K1600 GT
