Results 1 to 6 of 6
Thread: Need the bolt size!!! F750GS
    Registered User GaMtnGirl's Avatar
    Apr 2015
    Hiawassee, GA
    I got my engine guards on Friday and was all excited to start installing them on my 750GS. Of course the first item to be removed isn't coming off due to the bolt being stuck. I know they have likely used Locktite on this thing. I already feel like its starting to strip. ?? Anyone kno
    Attached Files Attached Files
    2019 BMW F750GS
    2014 BMW R1200RTW SOLD!
    2006 Yamaha FJR 1300A (gone)
    2012 Victory Cross Country Tour (gone)
    Registered User ackme's Avatar
    Mar 2019
    Parker, CO
    Quote Originally Posted by GaMtnGirl View Post
    On my bike it is a M6 bolt with a T-30 torx head. It came out without too much effort but there is evidence of blue locktite on the threads. Cant really put any heat on it with the plastic piece right under it.
    Mansfield,MA
    I think you are referring to the “Torx” size? It looks like the same setup as my F800GS.
    I would make sure the tool fitment was “solid” and tap the tool while turning. You could spray some WD-40 in the area and let it soak in a bit.
    Mod Squad
    2009 F800GS 1994 TW200
    Aug 2018
    Fargo, ND
    Many times I have seen guys using one size too small torx, or an allen wrench in place of a torx. Make sure you are using the correct tool and size and it is in good condition. Wrong size, wrong tool or a worn out tool and a extra tight bolt is guaranteed to lead to failure.
    From the only real Fargo, ND!
    Apr 2015
    Hiawassee, GA
    That worked perfectly! Thank you.
    2019 BMW F750GS
    Mansfield,MA
    Great!
    Mod Squad
  1. Thread (bolt) size
    By gregory in forum Oilheads
    Last Post: 03-20-2013, 11:23 PM
  2. What size bolt is it??
    By gnavecky in forum Oilheads
    Last Post: 07-01-2007, 03:48 PM
  3. Bolt size requested. . .
    By rowemesp in forum Oilheads
    Last Post: 04-02-2007, 08:33 AM
