Results 1 to 6 of 6
Thread: F800 Chain Wear
    F800 Chain Wear
    Hey All,
    I have a 2015 F800R with 14,600 miles. looks like I need a new "final drive". I was just curious about the mileage folks are getting out of the stock chain and sprockets for the F800 Bikes. I understand wear will be dependent on many variables (maintenance, riding conditions, load...etc) just taking a leisure survey. If you feel like responding just state year, model and mileage on original chain and sprockets before replacement. If you feel like providing your maintenance practices and average riding conditions feel free to do so. Thanks in advance.
    Spring is just around the corner folks, get ready for FUN!
    Dug
    Mansfield,MA
    There is some info in the F-Twin index- https://forums.bmwmoa.org/showthread...e-F-Twin-Index
    At the bottom left of the page you will see the "Tag Cloud" search box. As soon as you start typing, many "chain" threads show up.
    Personally, on my F800GS, I'm thinking at around 20K. If the bike is being thrashed in the desert, I would expect a bit shorter life. These "new" o-ring chains are pretty durable. If I went to 20K, I would probably do the sprockets as well. In the dirt bike days, with severe use, the sprockets would develop quite a "wear" hook to them.
    Mod Squad
    2009 F800GS 1994 TW200
    Apr 2015
    Southwestern Connecticut
    Chain and sprockets should always be replaced at the same time.
    2002 R1150R
    2016 BMW F700GS
    Mansfield,MA
    I try to provide advice in a manner that will give a poster information that will allow the poster to make an informed decision.
    Mod Squad
    Quote Originally Posted by lawrencecarlson View Post
    I've heard that and don't necessarily believe it for bikes used primarily on pavement. On our F650 Funduro bikes I laid an old sprocket on top of a new sprocket and the tooth wear was almost impossible to find so I put the old one back on. The second chain lasted just as long as the first chain. My approach is to actually examine the sprockets. If wear is evident by all means replace the sprockets. As an added aside, note that the front sprocket with about 1/3 as many teeth will theoretically wear faster than the rear sprocket, but in fact it also depends on the hardness of the sprocket material which may not be the same at all.
    Left Coast Rider
    Nov 2011
    I've had the same experience as Mr. Glaves. In the last 10 years and over 100,000 km on chain drive sport bikes I have yet to replace a sprocket. In comparison with the other folks with whom I ride, I find that proper lubrication with a quality chain lube makes all the difference in the world. It cushions the impact between chain roller and sprocket.
  1. Chain problems-2014 F800 GSA
    By LPD434 in forum F-Twins
    Last Post: 09-16-2014, 01:26 PM
  2. F800 Rt
    By roy in forum F-Twins
    Last Post: 10-03-2012, 02:54 AM
  3. TIRE WEAR...unique wear RT12
    By Rtinger in forum Hexheads/Camheads
    Last Post: 01-12-2011, 04:37 AM
