Where to mount a HEX EzCan and Fuzeblock on R1250GS?
tmwilmotte
Member
I test rode a 2020 R1200GS and looked under both seats for an area to mount a HEX EzCan controller and/or a Fuzeblock FZ-1 and discovered there is no room under the seats for any devices. The meager BMW tool kit has even been "embedded" into the bottom of pax seat to save space. And the battery shelf has been moved to just in front of and below the right side of rider's seat, hidden by a removable plastic cover.
So, my question is: Where would a new R1250GS owner mount a Hex EzCan and/or a Fuzeblock? Best solution?
I have a 1250rt and plan to mount a fuzeblock on it and would also be interested in any ideas on mounting it.
Hex ezcan is designed to be installed under pillion seat. The ezcan is a little bigger than a USB thumb drive. The access plug for canbus is located under seat frame toward the back of seat opening and fused battery wires run forward to battery connections.
pictured is a 2014 R1200rt with ezcan. The install instructions are the same for your R1250gs and a R1200rt.
https://www.hexezcan.com/installation/r-series-lc/
Sent from my SM-G955U using Tapatalk
I have a ezcan installed under the pillion seat. There is really nowhere else it can go since it uses the TPS connection to connect with the canbus on my r1250
