2014 R1200R Non BMW Top Box and Rack Options.
SteverinoB
Any suggestions re mounting a Givi Top Box to the back end of a 2014 R1200R. Would need rack advice too and would like to stay away from the factory option. Thanks in advance eh 👍
I went to Givi USA site and put in 2015 year model, came up with mounting system rack and another adapter plate I assume if you have existing rack. The problem is no 2014, is your bike a late 2013 or an early 2015? Cam head or Wethead?
I am using IPhone and not able to throw the links your way.
Have added a Givi on H’s 07 R12R using adapter but know model is different
The bike is a 2014 ... The last year non Wet Head R1200R model. I am thinking if bits are available for a 2013 then they will work on a 2014. The R1200R went wet in 2015 a year after the GS and RT. Thanks for the info re 2013 bits 👍
Best thing to do is call a Givi Rep or somebody who sells their products. I discovered that Givi parts will fit things within a year or so within the description in SOME cases, as it appears you are aware of. I had the same dilemma with my speed triple and a tank lock ring so they worked with me and it took 3 attempts but they got me set up. They paid for the shipping too
