Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: Bikes on the S.S. Badger
    Hi Michiganders and Wisconsinites. I am thinking about taking the Badger across the Lake on my cross-country trip this year. Has anyone done this before? What kind of tie-downs would you recommend and from where (to purchase)? Thanks - Mark
    Liaison 20774's Avatar
    Mark -
    I found some older threads here:
    https://forums.bmwmoa.org/showthread...Ferry-Tie-Down
    https://forums.bmwmoa.org/showthread...Tie-Down-Hints
    You can also try going to google and typing "site:forums.bmwmoa.org badger" into the search box...I saw quite a few more threads that seemed to be about this ferry ride.
    Hangered... but aimed out flyhi2cfar's Avatar
    Jun 2007
    The Cincinnati Ohio riverfront (Ky side) & the Cape/Space Coast of Flordia.... when not out -- "travel'n"
    Question
    In 2018, Badger tie-downs were of a "mixed condition"... some looked newer & nice, others well exercised & grungy/dirty.
    One thing to remember, the Badger and ALL OTHERS I've used everywhere... Alaska, Mexico, Canadian Maritimes & multiple rides stateside...
    Ferries USE Commercial Quality Equipment; not the stuff you usually see hanging in stores we generally shop.
    It's large & robust for strength & durability.
    Your friend in adapting this equipment is for you to bring multiple "Soft Ties"... preventing their hardware from directly touching the bike.
    Double them up & extend as necessary... they pack tight.
    "travel'n" John
    slave to gravity skibum69's Avatar
    Dec 2016
    New Melbourne, NL
    I used My Mosko Moto cinch straps on my last Alaska crossing, on the Newfoundland ferries I always use the ones provided. Personally rusty hooks direct to my bikes does not bother me.
    http://beerthief.ca
    ITSteve: ride in peace my friend
    save $5 on a new SmugMug account, use this coupon 7frrnSRiTt9Fk
    Sep 2009
    Chestnut Hill, MA
    You might want to consider the fast ferry at Muskegon/Milwaukee (https://www.lake-express.com). Transit time 2.5 hours vs. 4 hours.
    John Gamel - BMW MOA Consumer Liaison 2018-Present
    2015 Ebony Metallic R1200RT
    MOA #153274
    "We have met the enemy and he is us." Pogo-via Walt Kelly
    Quote Originally Posted by ExGMan View Post
    Thanks for mentioning this alternative. It might appeal to some riders. But, I am too old to care about an extra hour and a half on a boat if the alternative means I have to go to Milwaukee. I just don't like major cities.
    Jan 2016
    Central Illinois
    Agree
    Not only is Milwaukee unpleasant to drive through if you are heading west which you are the roads from Milwaukee funnel you South and west to northern Illinois or to the Madison area both cluster areas if you go north to miss these areas you might as well take the other ferry. I personally would ride around the north side of Lake Michigan to miss the Milwaukee, Madison areas.
    Edit: cycle gear has a nice set of tie downs
    The OP seems to be more interested in tie downs for the ferry. Just sayin'...
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    A few years ago on a trip to the New England states I thought we might take one of the ferries across Lake Michigan so I carried some soft ties my wife made and some light duty straps.
    We didn't end up taking the ferry but something basic like these should work.
    This was enough straps for two bikes.
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2006
    Nibley, UT USA
    On the ferries I’ve ridden, including the cross-gulf ferry to Whittier in Alaska, the crews have had no issues with me tying down my own bikes and appreciated that I came prepared. I carried a half-dozen soft ties and three or four regular tie-down straps that I normally use on my trailer—like the ones in Lee’s picture. On some ferries the tie-down points in the deck are configured to hold a t-shaped metal end on the ferry straps, but I had no trouble getting hooked in. If you tie the bike on it’s sidestand make sure to include a strap to tie the sidestand to the front fork so it can’t be accidentally retracted.
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    X-Troller hexst's Avatar
    N.E. Flawda
    On the Badger you tie down your bike. you ride it into the hold and put the front tire against the bulkhead(wall) next to other bikes parked the same way. there are ample tie downs of serious strengths as Travl'n John said use your soft ties on the bike and there are slots on the deck to anchor the hook end to, very steady.The bulkhead keeps bike from moving forward and the three point stance of the bike with the tires and sidestand combined with the straps works well.
    Knick
    R1200GS
    Vespa ET4
    Mansfield,MA
    Quote Originally Posted by GTRider View Post
    Best,
    DeVern
    Never been on a ferry but have tied a few things down. Along with the above, I like to have the bike in first gear and sometimes wrap the front brake lever to keep the wheel from turning.
    Big fan of Ancra cam lock straps.
    Mod Squad
    2009 F800GS 1994 TW200
    Registered Loser SHAG's Avatar
    Bradford, Pa
    Quote Originally Posted by mplisa View Post
    I've used Ancra Tie downs for decades. You only need 2 of them. https://www.amazon.com/Ancra-49380-1...%2C240&sr=8-10
    Don't forget to put your ticket in the jar at the store to win a pizza !
    Sep 2015
    Birmingham, AL
    ...and if you're of a certain age, don't forget to ask for the "Sr Discount" for your ticket.
    J Goertz
    BMW MOAL
    2015 BMW R1200RT
    2012 Triumph Bonneville SE
    Quote Originally Posted by SHAG View Post
    I've used Ancra Tie downs for decades. You only need 2 of them...
    Any photos of this 2-strap tie-down method?
  1. Badger lake, oregon
    By chasmrider in forum Off the Beaten Path
    Last Post: 09-25-2015, 03:34 PM
  2. SS Badger Discount for MOA Members?
    By 62373 in forum Rally Forum
    Last Post: 03-01-2015, 02:48 AM
  3. Replies: 7
    Last Post: 06-16-2013, 04:55 PM
  4. Badger Ferry suggestions
    By jademe in forum Ride Reports
    Last Post: 06-13-2008, 01:09 AM
  5. Route from Badger ferry to site
    By jshuck in forum Rally Forum
    Last Post: 07-06-2007, 12:28 PM
