Results 1 to 4 of 4
Thread: What lube to use?
    Jul 2006
    Buffalo, NY
    What lube to use?
    Doing a tire change on my 1979 R65. It's been awhile so I cleaned the rear hub splines. What lube is recommended for reassembly.
    Thanks, Jim
    19512
    Buffalo, NY
    1971 R75/5, 1982 R100/RS, 1978 Triumph Tiger (in bits)
    Feb 2005
    Trinity, NC
    Honda moly60 or whatever equivalent product is available now.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Liaison 20774's Avatar
    Snowbum's paragraph 6A has his recommendations for greases:
    https://bmwmotorcycletech.info/chemicalsetc.htm
    I found a tube of Chevron NLGI2 red grease and I mix it with moly wheel bearing grease at about 2/3 red grease with 1/3 moly.
    Houston, TX or Portland, OR
    From what I understand subscribing to this forum, the TS-60 from Ted Porter's Beemer Shop is the equivalent of the prior Guard Dog Moly spline lube. When my tub of GDM spline lube runs out, I'll order this from Ted for my splines.
    Jim (MOA 83200)
    '78 R80/7 (Anastasia) and '84 R100RS (The Millennium Falcon), '86 K75C (Icy Hot)
  1. Replies: 34
    Last Post: 03-28-2013, 12:16 PM
  2. lube mix
    By KARSTEN in forum Oilheads
    Last Post: 09-23-2012, 02:57 AM
  3. Gear lube ???
    By 40427 in forum Airheads
    Last Post: 10-27-2011, 02:09 AM
  4. Spline Lube-Lube question
    By robsara in forum Flying Brick K-bikes
    Last Post: 02-27-2010, 06:39 PM
  5. Spline lube on r65
    By wxpotts in forum Airheads
    Last Post: 01-12-2009, 05:36 AM
