Results 1 to 3 of 3
Thread: 2010 k1300S Need Assistance with License Plate holder
    Aug 2003
    Santa Clarita, CA
    The license plate holder Part # 46627658994, has become loose. It moves up and down. Just for reference, this part is the item on the rear of the bike, which contains the key lock to remove the seat. It also provides a mounting for the US License plate adapter. I figured that I just lost a bolt or a bolt become loose. I looked at this part in the microfiche and the life of me, I am unable to determine the location of the bolt, which supports or stabilizes the license plate holder. Do any of you know the location of the bolt to fix this issue?
    Thanks in advance
    Howard
    Howard
    Left Coast Rider
    If you look under your seat there are two bolts directly behind the tool kit holder which are part of the fastening system. I could be wrong but I believe this part slots into its location and is secured by these bolts. If its moving up and down you may have either a missing bolt or a broken/cracked plate holder.
    Aug 2003
    Santa Clarita, CA
    I look at your suggested solution
    Thank you for the reply. I look under the seat and see if I can determine the bolts you write about. I'll let you know.
    Howard
    Howard
  1. 2001 K1200rs License Plate Bulb Holder Help
    By meads77 in forum Flying Brick K-bikes
    Last Post: 08-07-2019, 04:32 PM
  2. License plate avatar
    By piperjim in forum Forum Software Specific Help. NOT for bike related questions.
    Last Post: 04-06-2010, 12:41 PM
  3. License plate numbers
    By r11rs94 in forum Photography
    Last Post: 03-22-2009, 03:05 PM
  4. License Plate Frames
    By barryg in forum Gear
    Last Post: 11-05-2008, 01:41 PM
  5. More license plate nonsense
    By Ridealot in forum Campfire
    Last Post: 11-12-2007, 12:31 PM
