bradramsey70
I'm having a no spark problem. Upon removal of my tank I immediately noticed what engine heat has done to my wiring harness....not pretty. The wires going into the hall ignition sensor connection are bare with no insulation left on them so I need the sensor with wiring harness to the plug located under the seat. I am only assuming the sensor itself is bad because I have no way to test it. The symptoms are rpm gauge stuttered at high rpm every now and then a couple months prior and suddenly shut down while riding this morning not to start again. I'm getting no spark at the plugs and the coil checks out ok. BMW wants $400 for the part. Anyone have experience with this? Am I on the right track with this diagnosis? Where can I buy one w/o breaking the bank? Please help me out if you can. The bike has 50k on it.
