Results 1 to 6 of 6
Thread: 2002 r1150r hall sensor with harness
    I'm having a no spark problem. Upon removal of my tank I immediately noticed what engine heat has done to my wiring harness....not pretty. The wires going into the hall ignition sensor connection are bare with no insulation left on them so I need the sensor with wiring harness to the plug located under the seat. I am only assuming the sensor itself is bad because I have no way to test it. The symptoms are rpm gauge stuttered at high rpm every now and then a couple months prior and suddenly shut down while riding this morning not to start again. I'm getting no spark at the plugs and the coil checks out ok. BMW wants $400 for the part. Anyone have experience with this? Am I on the right track with this diagnosis? Where can I buy one w/o breaking the bank? Please help me out if you can. The bike has 50k on it.
    Quote Originally Posted by bradramsey70 View Post
    Send a private message to GSAddict on this forum. He rewires these assemblies better than new.
    Yet another option is Cata Dan for either a re-built Hall Sensor unit or a new unit.
    https://boxer-upgrades.webs.com/apps/webstore/
    https://advrider.com/f/threads/water...plates.862122/
    Following is a nice write-up on repairing the Hall Sensor, including how to make an inexpensive unit to test the sensors.
    http://users.rcn.com/dehager/service...ll_sensors.pdf
    On my oilhead (94 R1100RS) it was only the wire insulation that failed in the high heat environment. One could replace the wire with some more suitable for the temperatures to which the unit is exposed. Stranded wire with silicone insulation rated for 200 degC should be adequate. Such wire is available from sources such as -
    https://www.adafruit.com/?q=silicone%20wire
    One might also want some shrink tube capable of withstanding higher temperatures available from several sources -
    https://buyheatshrink.com/heatshrink...teflon-ptfe-12
    https://www.te.com/usa-en/products/h...&tab=pgp-story
    https://www.cableorganizer.com/heat-...emperature.htm
    Jerry Emhoff
    Oct 2007
    southwest Michigan
    What Paul said. Iím a satisfied GS Addict customer. The wiring looks better than stock and the turnaround time was short.
    Winter is coming
    Jun 2017
    Tucson, AZ
    I got one from GS Addict and it has been great. He's nice to do business with.
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Thank you Gentlemen
    Ufda happens..........
  1. 2002 R1150RT hall sensor
    By BILLK75 in forum Oilheads
    Last Post: 11-23-2018, 08:46 PM
  2. Hall sensor done...
    By krash in forum Oilheads
    Last Post: 04-11-2017, 03:39 PM
  3. hall sensor?
    By 56216 in forum Oilheads
    Last Post: 05-22-2016, 06:34 AM
  4. New Hall sensor only firing one sensor
    By mark from maine in forum Oilheads
    Last Post: 05-20-2011, 07:10 PM
