Results 1 to 8 of 8
Thread: F800GS Headlight moves up and down a few centimeters
    Jan 2020
    Philly Suburbs, PA
    Just noticed the headlight moves up and down a few centimeters. I tried to tighten the left and right of the headlight housing but i can still move it up and down. Is this normal?
    Jun 2009
    Rochester, MN
    Nope, you should be able to tighten up the headlight so it doesn't move. I'd take out both of the bolts all the way, and verify that they aren't stripped. Make sure to catch the washers (if you have them), you'll need those to help with proper spacing.
    Lanark County near Ottawa ON
    Perhaps the metal inserts that the bolts screw into are not secure to the plastic headlight housing?
    Sent from my SM-T813 using Tapatalk
    Jan 2020
    Philly Suburbs, PA
    Left too many washers in. Removed and now works great. Touratech instructions were not very clear. You do not need 3 washers but only 2 (one from headlight to headlight bracket and one from Touratech bracket to screw) you do not need the washer from Touratech bracket to the headlight bracket.
    Sep 2012
    Lansing, Kansas
    Quote Originally Posted by epirusgr View Post
    Just a suggestion: you might check in at F800riders.org. They focus on the F800 series of bike and have lots of posters/riders who can help with this, and other, issues. There is a fair amount of crosstalk between that forum and this forum, but some real twin specialists over there.
    Good luck.
    Royce
    On the coast of Kansas
    2012 F800ST
    Jun 2009
    Rochester, MN
    Quote Originally Posted by royce View Post
    Good luck.
    Hey man - we're trying!!
    Good luck.
    Although the F800riders.org forum is fine, when it comes to the technical aspects of the F800/700.650GS bikes nothing beats the Parallel Universe forum over on ADVrider.com .
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Good to see you figured it out.
    Lee
    2016 R1200RS
    MOA # 30878
  1. '98 K1200RS Seat Moves, How to Make it Less Movey
    By goneregret in forum Flying Brick K-bikes
    Last Post: 05-18-2018, 10:50 AM
  2. Mothership moves
    By 36654 in forum Motorrad
    Last Post: 08-19-2016, 02:37 PM
  3. Announcement: "Land of Oz" Rally moves to Atchison, KS!
    By DonHamblin in forum Regional Midwest
    Last Post: 06-11-2015, 04:44 PM
  4. Clutch arm barely moves after disassembly
    By 3moskvichi in forum Airheads
    Last Post: 09-10-2009, 01:41 PM
