rall275
I've got a K75C built in 6-23-87 and can't get the choke (idle advance) adjustment to adjust anymore. I believe the cable is stretched as turning the end after loosening the nut does nothing. For both positions, my cold idle rpm is higher than spec. Can you confirm, at max choke position, there should be 1.5mm clearance between the idle stop screw and its stop. For lower choke setting, should be 3mm clearance.
It's stock, so do you think I have the low, standard, or high bar version of the choke cable? EME will be my supplier once I figure this out.
I'm suspecting the standard, but wanted to know if anyone knows so I don't have to remove it to measure.
Also, choke cable replacement, difficult job or easy?
Thanks for any input on the matter.
