Results 1 to 14 of 14
Thread: Keyless Ride Remote Fob RE-PROGRAMMING???
    Registered User atcguy's Avatar
    Jun 2010
    Cody, Wyoming
    The basic question: We all know that a new fob can be programmed to work on a bike, but... can a remote fob that was programmed for use on previous bike be RE-programmed to work on a different bike?
    Read something funny today about these things... situation was this:
    The guy had a 2017 R12GS, with 2 of the remote fobs. The bike came with one of course, and he later bought a 2nd as a spare. He then had it programmed to the bike, and both of them worked as advertised. Great...
    Fast forward the time and he's recently sold the bike in preparation for getting a new one. Knowing that new bikes only come with 1 remote fob... when he sold the bike, he kept one of the fobs to be reprogrammed & used with the new one.
    However, he's now being told that his plan won't work. That once a remote fob has been programmed to work on one bike, that the BMW coding will not allow it to be reprogrammed to work on another bike... thus requiring him to buy yet another new remote fob if he wants a spare.
    Is that correct?
    Tom
    2017 BMW R1200GS Rallye
    2014 Ford F-450 Platinum
    2013 Dutchmen Voltage 5th-wheel Toy Hauler RV
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Fobs are coded to a specific bike by VIN before being shipped from wherever they are made/stocked/programed. They are not transferable to another bike.
    Kevin Huddy
    Jun 2010
    Cody, Wyoming
    It was my understanding that only the metal key-bit itself was cut by BMW using the VIN.
    The keyless ride fob consists of 2 parts: the metal key-bit, and the electronic remote. Any key-bit can be inserted into the fob... and BMW sells replacements for those at about $25
    I know when I obtained a spare fob for my Rallye, I had to order it at the dealership with my VIN. It arrived about a week later... but the shop still had to program the electronic remote part to my bike upon arrival, so it was NOT associated with the VIN when new.
    I would think that for using it on another bike, all one would have to do would be to order a new key-bit that fits the locks on the new bike, and then have the electronic remote reprogrammed for it. I mean... I remember doing something similar with my Ford car & truck a few years back when the truck's remote lock fob got accidentally smashed in my garage. I took the extra one from the car, and reprogrammed it for the truck to save me from buying a new one. It's just a simple electronic transmitter like your tv remote.
    But anyway, in the case of my example, the guy says the dealer told him that isn't possible. I was simply wondering if that was true, if there was something new & weird in the BMW electronic matrix that prevents that... or if the dealer was trying to hustle him out of another $275 for a brand new remote?
    Tom
    Aug 2018
    Fargo, ND
    If the FOB is electronically linked to the bike with the VIN one shouldn't need to mate the FOB to the bike when you get a new FOB. I find it hard to believe you can't reprogram the FOB. What happens if your bike has some major electrical failure and a new ECM is installed requiring FOB reprogramming?
    As far as I understand the VIN is required for the flip out key. The FOB is generic.
    Try reprogram it to a new bike, it will work, or not, it can't hurt to try. If it connects you can order a replacement flip out key to fit the new bike.
    From the only real Fargo, ND!
    Registered User cap's Avatar
    Oct 2016
    Fort Collins, CO
    Quote Originally Posted by PoorUB View Post
    ...Try reprogram it to a new bike...
    Yes, this seems like an empirical question. However, having done this myself with a new fob purchased for my R1200RTW, I can verify that the process is confusing and that there are many variations of incorrect instructions that you will find on the web. I found some advice on this forum about accessing the antenna loop on the RT by removing two screws in the dash, and then gently prying the plastic away to allow me to get the new fob right next to the loop. Only then would the reprogramming work. While doing it, you will see a variety of key-shaped icons on your rider display. I found that I needed to use my original fob to start the bike, then while the bike was running, I moved the original fob far away, and then put the new fob immediately next to the loop. YMMV.
    I think I recall that on the GS, the loop is located under the rear fender (?) Good luck, and report back.
    Cap
    Jul 2007
    Big Sky Country
    Tom, Have your friend give it a try and let us know. I'm sure the dealer doesn't know what he's talking about or is a crook.
    Kevin Huddy
    Jun 2010
    Cody, Wyoming
    That's just it... the guy in the story isn't my friend. His story is something that was told to me, because I'm in a similar situation.
    I sold my Rallye just before Christmas. I was going to sell MY extra remote fob to someone, but he backed out when he said that he learned the info that I relayed. That something about the 2018 & up bike electronics prevents the bike's CPU from recognizing a previously coded key fob. Personally, I don't see how that is possible, as the key fob doesn't know it's been used... all it does is transmit it's own transponder signal. The bike's CPU does the processing & either recognizes the fob or not when someone tries to start the bike.
    In any event, I couldn't find any mention of a "re-programing" a fob online myself (plenty of info on programing a NEW fob, but not re-programing a used one)... which is why I was asking if anyone here had heard something similar.
    Tom
    Aug 2018
    Fargo, ND
    atcguy, let him try mate the FOB. If it works, he buys it, if not nothing lost.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    "How it's possible" depends on the design of the device. Some electronic chips can be programmed only once, and others can be programmed multiple times.
    Example: PROM = programmable read-only memory; EPROM = erasable read-only memory.
    So who actually has any facts on this topic?
    I am not interested in theory and speculation. Facts count.
    Cal
    Nov 2003
    Suches, Ga
    Paul,
    Fact is BMW dealer does not know anything and is a crook.
    Internet knows everything but cannot accomplish the given task.
    Cal Garcia
    Suches, GA
    Quote Originally Posted by Cal View Post
    Paul,
    I am very sorry your dealer is stupid and a crook. My dealer, and several others I have patronized for the past 35 years are both very knowledgeable and very honest. You need to find better dealers.
    Jul 2007
    Big Sky Country
    It was sarcasm........
    Kevin Huddy
    Yes it was.
  1. Replies: 11
    Last Post: 10-29-2019, 06:57 PM
  2. Keyless ride key fob?
    By PoorUB in forum Wetheads
    Last Post: 08-25-2019, 08:55 PM
  3. Tankbag for Keyless Ride
    By brookscooper in forum Wetheads
    Last Post: 07-05-2019, 02:55 PM
  4. Keyless ride
    By Dp1guzzi in forum Wetheads
    Last Post: 03-27-2017, 10:20 PM
  5. 2015 R1200R Keyless Ride Mystery/Oddity
    By rudyinla in forum Wetheads
    Last Post: 02-03-2016, 12:45 PM
