So, I bought a Zumo 595 for myself for Christmas to replace my old 550 with something more modern. I’ve torn down all my necessary Tupperware on my 2009 RT for ease of access. I cut the old harness wires hoping to tap into them since they are already wired into the front accessory circuit. Doing so should allow me to just splice the wires together and the new 595 should turn on and off with the key, correct?
Wrong.
It comes on with the key. Won’t turn off. Nor will anything else wired to the accessory circuit! My AdMore light stays on. Auxiliary driving lights stay on. I have to unplug the GPS socket from the front accessory plug to get those things to turn off.
I’ve tried: 1) Power and ground through front accessory plug = comes on with key but won’t turn off. 2) Ground to accessory plug/power direct to battery = GPS comes on as soon as connected to battery but other accessories function properly, GPS stays on. 3) Incorporated third wire (blue/white) to wires at accessory plug = back to 1.
Any help? Advice?
Wrong.
Any help? Advice?
