Results 16 to 30 of 43
Thread: DrNeo's F800GS Alaska/LDR bike build
  1. #16
    gig harborr ,wa
    I think it is a camel back tank.
  2. #17
    Jun 2009
    Rochester, MN
    Quote Originally Posted by vark View Post
    What is the white/silver box with the world map tucked under the right rear pannier mount?
    It's a tool box. Purchased from the Far East via eBay. The box itself is pretty well made, and hasn't let in any water, but I haven't had it chock full of tools on rough roads either.
  3. #18
    Neat. Looks like good use of otherwise empty space.
  4. #19
    New_AlaBeemer HSVPhil's Avatar
    Jan 2019
    Rocket City, AL
    Quote Originally Posted by GTRider View Post
    Donít be too quick to write off the F800GS. I flogged one for a couple thousand miles in the Balkans in 2018; never found it uncomfortable or lacking for power, and the lighter weight and crisp handling was appreciated.
    Just to chime in with 2 cents worth of experience; I put ~100K on my F800GS over 8 years. It is a perfectly acceptable world traveller, and you've already started farkeling yours! I appreciated the leg-room proffered by the bike's height (I also added some folding foot-rests to my crash bars. I could shift my butt to one side and stretch the other leg as necessary). I also took BMW's off-road training course in SC on their F800, so I felt confident in everything we tackled {BIA Rd #2 in Buffalo Gap, SD was gnarly tho, but that was deep sand vs gravel.}. And do have the right tires for your goals. I'd recommend Heidenau K-60s as the most useful tires for any purpose. They were a little noisy at first on the highway, but they're very durable & sure-footed! Lastly, I bought a small Air-Hawk seat pad for comfort. It suited me as an affordable solution to the generic BMW seat... Just have to pack it up when T'storms approach...
    https://www.heidenautires.com/product/k60-scout/
    Good Luck on your 2020 adventures - - we're headed to AK & YT on our summer National Parks Quest!
    CIAO! HSV-Phil & HSV-Karen
    https://dawsoncity.ca/event/d2d-moto...e-not-a-rally/
  5. #20
    Jun 2009
    Rochester, MN
    Thanks for the advice Phil and Karen!
    Well, I had big plans for yesterday, but then one of those "oh this should only take a minute or two" kind of projects blew up, consuming most of the day.
    Today's win was installing the plastic/rubber covers for the Pivot Pegz. Why these are not included is beyond me, seems a little overkill for how much they cost.
  6. #21
    Jun 2009
    Rochester, MN
    The Camel Tank auxiliary gas tank is installed and ready for action! This gives an additional ~2 gallons, which along with the 1 gallon peg packer, and the ~4.2 gallon stock tank should give me ~320 miles if I keep the bike returning my current average of 45.6 mpg.
    I'm still way under the Iron Butt Rally's 11.5 gallon limit...
    The whole process was pretty easy. Took longer because I was redoing and planning some wiring at the same time, but I think most people could do it in under 2 hours.
  7. #22
    Question Which windscreen hardware assembly is that?
    It looks adjustable.
    I know MadStad makes such a beast.
  8. #23
    Jun 2009
    Rochester, MN
    Quote Originally Posted by wildbears View Post
    Correct! It's a MadStad windshield.
  9. #24
    Quote Originally Posted by drneo66 View Post
    Good choice for a bike used for touring and at speed.
    Many dual purpose bikes have shields at a bad angle and also don't allow for relief of negative trailing pressure at speed (which is worse at certain angles).
  10. #25
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
  11. #26
    Jun 2009
    Rochester, MN
    A little slow going over the last couple weeks. I did complete my art project though:
  12. #27
    Jun 2009
    Rochester, MN
    Like many other F800 owners, it was time for new steering head bearings... not a bad job on this bike. Heating up the bearings via a heat gun, and freezing the stem by letting it sit outside in the snow, allowed the new bearings to drop right on!
  13. #28
    gig harborr ,wa
    How many miles are on this bike?
  14. #29
    Jun 2009
    Rochester, MN
    Quote Originally Posted by EUGENE View Post
    12,965 miles...
    I'll plan on double checking the bearing play after 100, 500, 1000, and 2000 miles.
  15. #30
    Mansfield,MA
    Iím curious as to the symptoms for the SH bearings?
    Thanks.
    Mod Squad
    2009 F800GS 1994 TW200
  1. Replies: 2
    Last Post: 11-01-2019, 09:32 PM
  2. Bike build facts
    By miker1200s in forum Hexheads/Camheads
    Last Post: 03-17-2016, 09:20 AM
  3. Bike Righting Jack-Easy to Build Design
    By oldnick in forum Motorrad
    Last Post: 07-15-2015, 08:48 PM
  4. Replies: 7
    Last Post: 04-04-2009, 04:39 AM
  5. Replies: 5
    Last Post: 09-05-2006, 03:27 AM
