DrNeo's F800GS Alaska/LDR bike build
drneo66
Active member
A few years ago I bought a 2009 BMW G650GS to attempt to accomplish the Iron Butt Association's famed “Ultimate Coast to Coast” ride, which is Key West, Florida to Prudoe Bay, Alaska. I made it from Minnesota to Key West, but the little thumper didn't make all the way :(
I went back to the drawing board and decided that a 2013+ F800GS would be a better bike for me to try again with (thanks to the input of everyone here). I was able to find said bike earlier this year, so this is the story of me setting up my new (to me) bike for some long distance riding. I've been fortunate to be able to complete a long list of Iron Butt Association rides – ranging from 48 states in 10 days, to the Piston Diversity Challenge. After all these miles and challenges, I feel like I know what works well for me and what doesn't. This will be the story of setting up this "new" bike for this adventure.
The bike was pretty well farkled already, but here's a list of things I'm going to do:
- Add two sets of aux. Lights (one set for conspicuity and the other set tied to the high beams for better down-range throw)
- Add a Denali CanSmart system – this will help reconfigure all of the auxiliary wiring that's on the bike as it's a mess currently
- Add a small top box
- Secure a way to carry extra fuel. I have a Best Rest peg packer already, but I may explore the Camel Tank
- Install a MCCruise cruise control system – this will be a big project
- Set up the suspension for proper sag
- Brake fluid flush – I did one when I first got the bike (the first flush that the bike has had since it was new AFAIK), but I like to flush my brake fluid in all my bikes each year. It - doesn't take long and prevents some very, very expensive parts from having problems in the future. Also, it could reduce the likelihood of becoming a hood ornament.
- Install Scottoiler – reduces the time I need for chain maintenance during long rides
- Replace steering head bearings because they already have slight notches :banghead
- Replace wheel bearings – reducing the chance for more problems
- Repack the swing arm bearings? Haven't decided yet if this is necessary
- Finally I'll add some reflective tape to the back bags to increase conspicuity
Now, I fully understand that I probably don't need much of the above list to go out and ride, but I have big plans beyond just Alaska for the rest of the year and 2021 :)
A picture of how the bike came home:
Before starting:
Here's where I'm currently at:
Very ambitious undertaking.
Personally, I'd put the time and effort into your RT for such a trip.
Good luck!
Joe
I have made two trips to greater Alaska as far as a bit north of Fairbanks. I have made a half dozen trips to Hyder. I have never gone to Prudoe Bay since 1970 in the Air Force and have zero desire to go there on a motorcycle.
As for this thread, a person can go to Alaska on an RT, or a Goldwing, or a moped. But a dual-sport motorcycle would be my choice for sure. In 1991 I rode a R80G/S Paris Dakar. In 2008 I rode a G650 Funduro. Both were middleweight dual-sport bikes and both were very welcome on the stretches of construction going from mud to dirt to baseball size rocks to golf ball size rocks to river rock to gravel and finally again to pavement. Both times we encountered a few stretches of such construction. Sure a good rider can make it on an RT but good luck in the vicinity of Destruction Bay in the Yukon. This is the area where the road is built on a bog where they had to sink logs in the muck to build a road base when building the Alaska Highway in the 1940s. It is still a mess under construction every year. The approach is to tear it out and rebuild it, and to allow traffic to compress the new gravel roadbed. And they use copious amounts of calcium chloride to control dust, but which when wet is as slick as frost on a doorknob and which when dried on your bike is like shotcrete sticking to everything.
I don't us vice grips to tighten head bolts. I don't use a claw hammer to test relays. And I don't ride a street bike through construction zones going to Alaska. Not when correct equipment can be available. YMVV.
As for this thread, a person can go to Alaska on an RT, or a Goldwing, or a moped. But a dual-sport motorcycle would be my choice for sure. In 1991 I rode a R800G/S Paris Dakar. In 2008 I rode a G650 Funduro. Both were middleweight dual-sport bikes and both were very welcome on the stretches of construction going from mud to dirt to baseball size rocks to golf ball size rocks to river rock to gravel and finally again to pavement. Both times we encountered a few stretches of such construction. Sure a good rider can make it on an RT but good luck in the vicinity of Destruction Bay in the Yukon. This is the area where the road is built on a bog where they had to sink logs in the muck to build a road base when building the Alaska Highway in the 1940s. It is still a mess under construction every year. The approach is to tear it out and rebuild it, and to allow traffic to compress the new gravel roadbed. And they use copious amounts of calcium chloride to control dust, but which when wet is as slick as frost on a doorknob and which when dried on your bike is like shotcrete sticking to everything.
90-95% of his route/riding will most likely be on paved roads.
That little 800 will get old real quick.
To paraphrase: I wouldn't ride a small dual purpose bike for over 5,500 miles on paved highway when correct equipment is available.
YMMV
Joe
YMMV
Don’t be too quick to write off the F800GS. I flogged one for a couple thousand miles in the Balkans in 2018; never found it uncomfortable or lacking for power, and the lighter weight and crisp handling was appreciated. And I am not a small person—quite the opposite. That bike had more power than the R100GS I rode to Tuktoyaktuk in early June of 2018, a 9500-mile round trip. The two most disappointed riders I met on that trip were a couple of GSA riders I leapfrogged with going up the Dempster. They, too, were headed for Tuk but turned back to Inuvik after each had been down for the third time—wrestling that much bike in that much muck was just too much.
Paul is absolutely correct about Destruction Bay. I came through in 2018 on the R100GS and lucked out—weather was dry and construction not yet in full swing. Last June, returning from Anchorage in our K-bike sidecar, it was raining every day so my wife and I avoided Destruction Bay and did the Top of the World Highway to spend a couple days in Dawson before heading to Whitehorse and down the Cassiar.
Best,
DeVern
YMMV
Joe
We will just have to disagree. In the past two summers I have put over 20,000 miles touring mostly but not entirely on two lane paved roads on a small dual purpose motorcycle. Last summer we rode from Texas to Tennessee to Virginia to British Columbia and back to Texas on our G310GS bikes. Calling an F800GS a small bike is in my opinion a complete misnomer.
We lived in Fairbanks for almost 17 years and made the trip between Alaska and the states several times, and also rode the Dalton half a dozen or so times (only once to Deadhorse). Four of my rides were on a 07 RT and Annie rode a F650GS single and a F650GS twin on most of her trips and two on a F800GS. My riding on the Dalton was on either a F650 Dakar or a R100GSPD; Annie’s was on her thumper. My point.... for the ride up and back just about any bike can handle the trip. Harley baggers, Goldwings and a variety of cruisers make the trip every year. Just know that you will likely encounter construction zones 30-40 miles long and could easily ride 150 total miles in construction zones. However, once you get to Alaska it will be to your advantage to have some off pavement capability. There are dirt roads to ride other than the Dalton. The Denali Hwy is a great ride of about 125 miles of dirt road. It was once the entrance to Denali NP and now connects the Richardson Hwy at Paxson with the Parks Hwy at Cantwell. Ride it from East to West if possible and you’ll have Denali Mountain in your wind screen for 40 miles. Manley Hotsprings is on the Elliot Hwy and you’ll ride about 80 miles of dirt one way. It is a trip back in time and village of less than 90 people, but has a roadhouse. Along the way you can stop at Minto and see an Anthabaskan village of around 250. You can also enter or leave Alaska on the Taylor Hwy/Top of the World Hwy; About 150 miles of mostly dirt.
The F800GS is a very good choice for all of this. It has more than enough power and can comfortably cruise on our 80 MPH interstates yet it is quite capable off pavement. Annie still has her F800GS as well as a 2017 R1200GS. When we talk about riding back to Alaska and the Yukon she says she might take the F bike.
....Calling an F800GS a small bike is in my opinion a complete misnomer.
:thumb
I am a guy looking for my next bike and beginning to feel an F700/800 is too BIG. No chance will I be looking at anything larger...
To the OP, ignore this distraction/debate and keep your photos coming. Lots of us will be interested to see your preparations.
Thanks everyone for the comments and advice so far - this is exactly why I wanted to post the build! :)
Like Joe brought up, I could have probably done it all on my RT, but it's such a beast and the thought of wrestling it up the Dalton Highway with ~300 miles of gravel didn't sound fun. I thought about selling the RT and purchasing a R1200GS, but that's another big bike too, so this is where I landed. Coming from the K75, the F800 is pretty similar, but has more torque and slightly more HP (10 HP difference between the two). The F800 isn't as smooth as the K75, but it's not nearly as bad as most would think. Once it's all set up, I have no doubt that I'll be able to eat some miles, both on and off road, with this bike just as easily as the K75 or RT.
Yesterday was spent fitting the BestRest Peg Packer. I'll use this as extra insurance throughout the UCC trip, but it won't live on the bike full time. The can holds a little over 1 gallon.
I also spent time looking at where I want to mount my Caribou Top Box. There's like 200 holes drilled in the thing for various bikes, but none line up for the F800GS :banghead - That's the price you pay when you buy stuff that's used.
Peg Packers are a great piece of kit. Annie used them on her F650GS thumper until we loaned them to Doris Wiedermann when she rode a F800GS on the UCC in February. She kept them and they were replaced by Best Rest.
What is the white/silver box with the world map tucked under the right rear pannier mount?
It's a tool box. Purchased from the Far East via eBay. The box itself is pretty well made, and hasn't let in any water, but I haven't had it chock full of tools on rough roads either.
Just to chime in with 2 cents worth of experience; I put ~100K on my F800GS over 8 years. It is a perfectly acceptable world traveller, and you've already started farkeling yours! I appreciated the leg-room proffered by the bike's height (I also added some folding foot-rests to my crash bars. I could shift my butt to one side and stretch the other leg as necessary). I also took BMW's off-road training course in SC on their F800, so I felt confident in everything we tackled {BIA Rd #2 in Buffalo Gap, SD was gnarly tho, but that was deep sand vs gravel.}. And do have the right tires for your goals. I'd recommend Heidenau K-60s as the most useful tires for any purpose. They were a little noisy at first on the highway, but they're very durable & sure-footed! Lastly, I bought a small Air-Hawk seat pad for comfort. It suited me as an affordable solution to the generic BMW seat... Just have to pack it up when T'storms approach...
https://www.heidenautires.com/product/k60-scout/
Good Luck on your 2020 adventures - - we're headed to AK & YT on our summer National Parks Quest! :thumb
CIAO! HSV-Phil & HSV-Karen
https://dawsoncity.ca/event/d2d-motorcycle-ride-not-a-rally/
Thanks for the advice Phil and Karen! :wave
Well, I had big plans for yesterday, but then one of those "oh this should only take a minute or two" kind of projects blew up, consuming most of the day.
Today's win was installing the plastic/rubber covers for the Pivot Pegz. Why these are not included is beyond me, seems a little overkill for how much they cost.
