Results 1 to 8 of 8
Thread: 06 R1200RT: Bike won't start after servo brake removal
    Registered User tasslehawf's Avatar
    Feb 2016
    Austin, TX
    I recently tore out my servo brakes and replaced them with hard brake lines. All is good with that. I did remove the servo unit but ket the ecu plugged into the wiring harness.
    When I put the bike back together, it wouldn't start. My hex tool is telling me: 10167 : Output stage to Electric Fuel Pump faulty
    This would seem to point to the Fuel Pump Controller, but I tested it with a brand new one I just installed in another bike. Could it be the fuel pump?
    I was careful to reinstall all the connectors to the fuel tank and double checked in the service manual.
    2014 Triumph Speed Triple
    2007 F800S
    2006 R1200RT
    Registered User jandhumphreyme's Avatar
    Sep 2013
    Central Maine
    Do you have power to the fuel pump?
    So often times it happens that we live our lives in chains
    And we never even know we have the key
    Feb 2016
    Austin, TX
    Quote Originally Posted by jandhumphreyme View Post
    It gets about 10 volts (on start). I tried turning on the power and starting the ignition with the pump out of the tank to see what it does.
    It jerks once with the power on. With the ignition, it jerks again - and then again a couple seconds later.
    2007 F800S
    2006 R1200RT
    Mansfield,MA
    Possibly battery voltage low?
    Mod Squad
    2009 F800GS 1994 TW200
    Feb 2016
    Austin, TX
    Battery has been on a trickle charger.
    2007 F800S
    2006 R1200RT
    Mansfield,MA
    Quote Originally Posted by tasslehawf View Post
    I would try watching the battery voltage while you try to start the bike.
    Mod Squad
    Feb 2016
    Austin, TX
    What numbers should I be looking for?
    2007 F800S
    2006 R1200RT
    Mansfield,MA
    Over 12v would be great. Sometimes a “good” looking battery can be drawn down hard with the starter- leaving nothing for the other functions. The computers need to see at least 9.2v during the start cycle.
    Mod Squad
  1. 05 R1200RT ABS/Servo Problems & Removal
    By promptcritical in forum Hexheads/Camheads
    Last Post: 03-26-2018, 08:15 PM
  2. Help please - bike won't start... 2008 R1200RT
    By nelliott in forum Hexheads/Camheads
    Last Post: 06-09-2012, 04:21 AM
  3. Servo Brake Problem
    By dzacco in forum Flying Brick K-bikes
    Last Post: 07-09-2009, 05:30 PM
  4. R1150rt - Bad Brake Servo
    By DAVIS2X1 in forum Oilheads
    Last Post: 06-10-2008, 09:28 PM
  5. Brake Fault / ABS Servo
    By BouncinBob in forum Flying Brick K-bikes
    Last Post: 08-16-2004, 12:28 PM
