Results 1 to 7 of 7
Thread: 1150 RT Neutral Light issue
    hello I have an issue with my 2004 1150RT. The problem is that the neutral light is not working, this occurred a the same time that my side stand switch stopped working. The bike only has 12000 mile on it and I baby it a lot. Question, has anyone ever had a similar issue and are the two connected? Any suggestions would help. Thanks
    Liaison 20774's Avatar
    One of the threads in the Similar Threads pane below is for Oilheads...that thread leads to another thread that might provide some insight.
    No, the two are not connected if it is switch failure. The neutral switch usually fails when oil seeps into the switch and contaminates the contacts. I don't know of any specific pattern for sidestand switch failure. If that were my bike, before I bought new switches I would trace the wiring and unplug, clean, and reconnect any connectors I found. Then if the problems persist new parts may be in order.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    I am assuming the bike starts - right?
    Does the RID display the gears correctly?
    On the 6 speeds the neutral switch is part of the gear selector switch, unlike the 5 speeds that have a separate microswitch to annunciate neutral.
    First check that the lamp is functional.
    Troubleshoot as below
    Ignition B+ (green black) to one side of the neutral lamp then exits as (brown black) to pin 7 of headstock multiplug becomes (brown violet) to pin 5 of the of the transmission switch plug where it gets grounded via pin 1 (brown) in the neutral position.
    Ufda happens..........
    Neutral Light
    Quote Originally Posted by mor007 View Post
    Does the RID display any gears, 1-6? It's the Gear Box gear indicator that lights the neutral light AND displays 0 in the RID.
    Also, check fuse #1, as it powers the neutral light with key on.
    Feb 2008
    Quote Originally Posted by RPGR90s View Post
    Just a heads up, 0 on the RID is a different section of the switch than the neutral lamp annunciation.
    Feb 2008
    Pins 1 & 5 are the neutral light circuit
  1. Neutral to 1st issue
    By lbnyc in forum Wetheads
    Last Post: 12-22-2017, 06:36 PM
  2. Neutral light always on
    By rbleau in forum Airheads
    Last Post: 07-02-2009, 06:44 PM
  3. Neutral Light
    By grumpyone in forum Oilheads
    Last Post: 09-15-2008, 11:34 AM
  4. R90/6 Neutral Light
    By dasBiker in forum Airheads
    Last Post: 12-01-2003, 06:17 PM
  5. Neutral light gone.....
    By HERRBAYEMVAY in forum Airheads
    Last Post: 07-02-2003, 04:51 PM
