Results 1 to 10 of 10
Thread: 2013 K1600gt coolant low
    Dec 2018
    Minneapolis
    I just picked up a 2013 k1600gt with 21k miles and I was looking it over once I got it home and I can't see any coolant in the plastic container. I am planning on taking the Tupperware off this weekend to add some more.
    Are there things I should be looking for as I do this? Do I need to be concerned?
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Welcome to the forum!
    Congrats on the big K.
    You don't need to take all the plastic off.
    Remove the R/S air deflector and a couple screws on the fairing and you should be able to get to the overflow tank.
    Make sure you add the right spec coolant. I use Pentosin; thats what BMW uses. I believe its the "blue" formula.
    I assume you checked around the motorcycle for leaks?
    Its not unusual for coolant to be a little low.
    If no leaks; you should be OK.
    Maybe see you on the road come spring.
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Dec 2018
    Minneapolis
    Thanks Joe.
    I am going to get some of that coolant (pentosin nf) from O'Reilly along with distilled water. Looked at the screws last night and it seemed like I need to pull off that lower radiator bezel as well. You are saying I won't need to pull that one?
    Thx
    Mar 2014
    Apple Valley, MN
    Well you can if you're going to pull everything off.
    If you remove the deflector and two screws in the front, you can gently pull the plastic away from the frame enough to get in there with a long funnel.
    But if you're not comfortable doing that, then yes, remove the lower bezel and the screw under the front of the seat (and a couple others).
    Joe
    Aug 2018
    Fargo, ND
    Add coolant and keep an eye on it. I wouldn't worry about it. As much hassle it is to add coolant it might have gotten ignored.
    From the only real Fargo, ND!
    May 2015
    West of Rockies
    Do validate the water pump is not leaking. There were problems with wp design early on.
    I have gone through three of them under warranty.
    Dec 2018
    Minneapolis
    Great replies.
    * there are no leaks from the water pump or anything else
    * I have since done several cycles of running the bike for 20 minutes and letting it cool down. I have done the last 2 cycles on the side stand instead of the center stand because of a thread I read about how the side stand may be better for releasing trapped air
    Do these bikes have a history of using coolant?
    Mar 2014
    Apple Valley, MN
    Quote Originally Posted by jimijene View Post
    Nope.
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    Radiator gets moved/disconnected for valve checks, which is every 18k miles. Quite possible the mechanic that did the work, didn't burp the system and top off so it pulled from the reservoir. Just fill with, like the link someone else posted and keep an eye on it. And watch the water pump area.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA 2013 K1600GT
  1. 2013 K1600GT - Is there any height adjustment for the GPS cradle ?
    By desmoderek in forum Straight 6 K1600 GT/GTL/B
    Last Post: 07-09-2018, 01:30 AM
  2. Replies: 4
    Last Post: 06-23-2018, 02:38 AM
