Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Do THESE cam lobes look OK?
    Registered User dlong0609's Avatar
    Jul 2014
    Sedona AZ
    Imagine my disappointment to find this mess during the 24K service on my '18 RT. Everything looked fine at the 12K check. I've used only Castrol Power 1 4T 5W-40 since new. Clearances are within spec and have barely changed.
    You may have seen an earlier post from me relating a similar problem an a new '18 RT which was discovered at 800 miles! After negotiation with the dealer and BMWNA, I received a new '18 RT. The original bike received new intake and exhaust cams and presumedly has found a new owner.
    The exhaust cams appear OK...some fine scratches on the business end of the lobe, but no ridge that I could detect. As you can see, the intake cams are shot...far worse than the damage noted on the original bike.
    It's going back to the dealer this coming week.
    Nov 2017
    Collierville, TN
    Wait. So are you saying you had one before, a different R12LC, and it had the same problem only at 800 miles? And they gave you a whole new motorcycle???
    You must have mad negotiating skills (or you know where the dealers children go to school or have some other nefarious skill we shouldn't ask about).
    Two identical failures happening to the same owner on two different motorcycles. I'd kill to see the Weibull for that.
    Jul 2008
    Central PA
    Putting the warranty issues aside. And, I would want it repaired/replaced, if possible.
    But, you are at 24K and the clearances are OK. While not pretty, I'm curious what they'll look like at 48K.
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
    1) My expectations are never low enough & 2) Incompetence is infinite ........David Brooks
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Ouch, that's crazy to have the same serious problem on 2 bikes.
    Lee
    2016 R1200RS
    MOA # 30878
    Quote Originally Posted by dlong View Post
    ....After negotiation with the dealer and BMWNA, I received a new '18 RT. The original bike received new intake and exhaust cams and presumedly has found a new owner....
    Now we know who the new owner of the old bike is!
    Jul 2014
    Sedona AZ
    I noticed from the VINs of the two bikes that they came off the line within about 400 units of each other. I'm hoping that the cams in each bike came from the same lot, likely with the same defective case hardening process. No way to know for sure. I've seen heresay reports of wethead owners with similar problems, but please chime in if you share my experience.
    Sep 2013
    Central Maine
    I dont know as of yet how my '18 will be, just purchased it last September and only have 2,500 miles on it. What was the manufacture date of the two units you've had go bad?
    Jul 2014
    Sedona AZ
    Bike #1...1/18 bike #2...2/18
    Apr 2006
    Nibley, UT USA
    Well, now you’ve got me concerned. My GS has a production date of 3/18.
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    This has been going on for a lot of years.
    I was asked to check the cam sufaces when I did all my cam checks and was how I became aware of it.
    In 30 something bikes I have never seen a bad cam lobe.
    I have seen many posts of this issue though. Nobody is safe on this issue at any mileage.
    It is said to be bad heat treating and it can show at 1000 miles or 20,000 miles, that is the kicker. No way to tell how deep the surface treatment was and if it is good.
    I guess replace the cams and do very close oil changes a time or two or three?
    I have never seen pictures of chunks as they say the cam flakes so if there is any positive it is that. Pretty much sucks though and I pull my valve covers with every service so if I ever see the beginnings of this, BMW will no longer exist for me.
    Lee
    2017.5 R 1200 GSW
    May 2003
    SW Iowa
    Quote Originally Posted by LFarling View Post
    When we bought our bikes in 2016 the shop warned me about the problem and said to keep an eye on the cams at valve checks.
    They had replaced cams but did not say how many.
    Lee
    2016 R1200RS
    MOA # 30878
    Jul 2014
    Sedona AZ
    My dealer has confirmed the worn cam lobe issue and ordered new cams and followers. I understand the service includes oil change and filter replacement even though I had done those services just prior to bring in the bike. Despite the large amount of material missing from the cam lobes, there was nothing on the drain plug. If the material was coming off in macroscopic chunks, it seems there should have been some material on the drain plug. I'm concerned for the long-term health of the motor but unsure what if anything to do. Any thoughts? (Aside from selling or trading it)
    Fix it. Ride it.
    Sep 2013
    Central Maine
    There are so many variables to your question I don't think anyone can clearly and definitively answer your question. Depending upon the material of construction of the camshaft and size of particles shed, they may not stick to the drain plug. As for engine damage depending upon the shed particle size, they may be small enough to pass through engine oil clearance without affecting engine wear any worse than typical environmental conditions. A sampling of the engine oil may give you indication of wear.
    It's a disconcerting issue for sure, and something that wrankles me as well, we've been making camshafts for years and you would think that by now the technology would be proven out. I guess my thoughts would be run the guts out of it every chance you get, try and not let it bother you and enjoy. If it helps I'll buy you a beer in MT next June.
    Jul 2014
    Sedona AZ
    Quote Originally Posted by jandhumphreyme View Post
    Think I'll do what he said.
  1. Do these cam lobes look okay? 2017 R1200GSA
    By akbeemer in forum Wetheads
    Last Post: 12-30-2019, 01:20 PM
