Hello,
My 2011 R1200gs ESA front shock is leaking after 16,000 miles of brutal freeway use.
EPM will rebuild it for $300 which is better than having to replace it.
Removal looks simple enough, but the top electrical connector to the motor does not want to disconnect.
I have the (full) gas tank moved back about 1” to access the top shock bolt. Does the tank need to be removed to get at the electrical connector?
Thanks.
Thanks.
