Results 1 to 15 of 19
Thread: Dam Rat...Nav replacment
    924CBB2C-6D2D-41D0-9607-4FDF14C4F238.jpegWell guess a Rat had a nice rubber snack at my expense.
    Anyone have suggestions for a replacement that will fit my 05 bmw r1200rt? Not certain I want to buy a new nav VI just yet and missed their 20% off sale recently as well. Just found out about this issue today when at the bike shop getting service. My own fault it seems, happens when you leave a bike in a garage a long time plus leave a dryer vent hose open to the outside when moving a dryer around. Woke up early today then tossed a Bmw tank bag on the tank that hide most of the nav lol.
    Uncertain anyone has a dead unit they could send me and I then try to change out the outer shell casing. It is so old uncertain it would be worth the effort. I do though like having a bmw one attached to the bike connector plate plus powered by the bike.
    Registered User 36654's Avatar
    Jul 2008
    Central PA
    Quote Originally Posted by motor4 View Post
    If the wiring is undamaged........epoxy a plug in place.
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
    1) My expectations are never low enough & 2) Incompetence is infinite ........David Brooks
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    You must of had peanut butter on your finger when you turned the GPS on or off. It sure did take that button off that thing whatever it smelt on the button.
    Lee
    2017.5 R 1200 GSW
    Quote Originally Posted by 36654 View Post
    That can work. Seems that was an Ďoffí button as one can take a pin and press a button toggle within to turn it off. Will also check the ads for used navs.
    Wills Point, TX
    Years ago I had a Zumo 550 on/off button fall off, Garmin was great they replaced at no charge. I'd call them to see what they can do for you.
    Sometimes you cannot win it seems. Less then 24 hours after my service the fuel strip dies. Beyond the 2 year time period when last replaced after being replaced with bmw one time 10 year grace period. Kiss another $400 plus good bye.
    Me thinks I should have sold the back last year...
    Mansfield,MA
    Donít worry about it.......Use your trip odometer........you will be fine.
    Mod Squad
    2009 F800GS 1994 TW200
    Debbie's Servant Lee's Avatar
    SW Iowa
    This place has a good reputation and cheap rates for repairs.
    https://www.palmdr.com/cart/garmin-z...ice-p-368.html
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    Search the Hexhead/Camhead forum for the process to zap it with a lighter. That has worked for lots of people and will cost you more like $10. Its worth a shot.
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
    Wills Point, TX
    I agree with Lee. I had my wife's Garmin Drive (broken screen) repaired and a couple of buds had different Zumo's repaired.
    Feb 2005
    EastDakota
    I also used the palmdr repair in Mankato, Mn. to repair a Garmin. Great service and quick turnaround.
    SW Iowa
    I've also seen posts where palmdr will install new maps cheaper than the owner of the zumo 550 can while it's in for repairs.
    Lee
    2016 R1200RS
    MOA # 30878
    I used a silicone bead and a pencil eraser to fix mine.
    Knight-Errant 1957mpd's Avatar
    Feb 2018
    Las Cruces,NM
    My first three VW Beetles as a teenager did not have a gas gauge or a trip odometer; just a handle to pull for the reserve tank. Only time I ever ran out of gas completely was just as I pulled up in front of the pump. The fill-up ate an entire five dollar bill.
    "Solů el que ensaya lo absurdo es capaz de conquistar lo imposible." Miguel de Unamuno 1905
    Mark - Las Cruces, NM - '17 R1200 GSA
    SW Iowa
    There's a Nav V for sale for $300 shipped on the ADV site.
    https://advrider.com/f/threads/bmw-n...ition.1420231/
    Lee
    2016 R1200RS
    MOA # 30878
  1. '95 K1100LT Tire Replacment
    By jayskerdoo in forum Flying Brick K-bikes
    Last Post: 06-11-2018, 01:26 PM
  2. R1200rt brake pad replacment
    By bmw4life in forum Hexheads/Camheads
    Last Post: 10-12-2011, 02:04 PM
  3. Battery Replacment 1200 GSA
    By heloguy1976 in forum Hexheads/Camheads
    Last Post: 04-18-2010, 05:19 PM
  4. PIAA Replacment Parts
    By john832 in forum Oilheads
    Last Post: 05-01-2009, 08:53 PM
  5. Shock Replacment 92' R100RS
    By katoom in forum Airheads
    Last Post: 11-03-2004, 01:27 AM
