Results 1 to 7 of 7
Thread: Front Flat - Replace tire?
    Jul 2018
    Corralitos, CA - Santa Cruz County
    Road 3 with less than 1000 miles, small hole about an inch from centerline. I plugged it so I could get to work and back for two days. Should I just replace the tire or is getting a patch on the inside of the tire safe enough?
    Signature
    Quote Originally Posted by chrisinsc View Post
    I would use a mushroom plug (combination patch/plug). This seals like a patch from the inside and also plugs the puncture to prevent the penetration of any moisture or anything else between the plies via the puncture. Belt and suspenders if you will.
    Nibley, UT USA
    Plug & patch units like these are available at many auto parts stores and MC or ATV shops.
    Best,
    DeVern
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    Registered User mikegc's Avatar
    Oct 2017
    High Point, NC
    I had a puncture on a front tire on my way back from Alaska last year and, for a bunch of miles, there was no opportunity to replace the tire. I've had/used several patch kits before settling on a Neeley Repair Kit, https://www.nealeytirerepairkit.com/repair-kits. When I got to a dealership in Montana, I got them to change the oil. By that time, I had almost 2000 miles on the plugged tire and decided to ride home on it. Neeley makes a great product. (I'm not affiliated with them.)
    Mike
    I've had several tires repaired with rope plugs and last until they were worn out without issue.
    wanderer
    Jun 2009
    Bridport Vermont
    Quote Originally Posted by danm View Post
    Me too! Just ride the bike.
    Jul 2018
    Thanks all!
    Signature
  1. Patch, plug or replace flat tire on my R1150RT?
    By joebiker in forum Oilheads
    Last Post: 04-30-2015, 06:24 PM
  2. Had a flat. Replace tire?
    By jcofwmburg in forum Airheads
    Last Post: 05-05-2013, 04:45 PM
  3. Flat ridge in the center of front tire?
    By jconway607 in forum Oilheads
    Last Post: 10-17-2012, 02:40 AM
  4. My First Flat Tire
    By cookie in forum Motorrad
    Last Post: 11-05-2010, 09:18 PM
  5. flat tire help?
    By mohan0 in forum Oilheads
    Last Post: 10-05-2009, 08:25 PM
