Results 1 to 7 of 7
Thread: K1600GT O2 Sensor Connector Location
    Florida & Massachusetts
    A friend of mine just bought a 2019 K1600GT. I'd like to help him with some projects he's got in mind. One of which is to try a pair of AF-XIEDs. I've got little experience with this model and I'm wondering where the O2 sensor connectors plug in, and how best to access them. It appears they're under the tank but I'm hoping they can be accessed from the side. Any insight would be appreciated.
    Registered User d martin's Avatar
    Dec 2007
    SE Alberta
    @Roger 04 RT
    BMW-Motorrad
    (-) Securing left oxygen sensor
    Route cable (1) for the oxygen sensor between engine (2) and gearbox (3) and secure it.
    Route cable (1) for the oxygen sensor and secure it in holder (2).
    Appears to plug in behind frame spar by left knee position.
    BMW-Motorrad
    (-) Securing right oxygen sensor
    Route cable (1) behind coolant pump (3).
    Route cable (1) for the oxygen sensor and secure it in holders (2).
    Doesn’t show plug location.
    @d martin
    Thank you. Thatís a great help. Another reply suggest that the tank probably doesnít need to be removed.
    Dec 2018
    Nashville, Tn. Panama city beach, FL
    Hey Roger,
    I would be interested in some follow up as I am considering adding af-xied to my GT as well. I have one on each of my 01 GS's. location of connections and how it changed the performance. if you can would be very appreciated.
    Thanks,
    Rick
    Dec 2007
    SE Alberta
    K1600ís AX-FIED
    Roger said he would be posting results on K1600forum.com
    Dec 2018
    I placed this post on the K1600 forum as well. installed the af-xied on my 16 K16gt last night. pulled plastic panels as if doing air filter change but stop at just the side panels. no need to pull the center piece. the o2 connectors are obviously displayed and fastened just about knee level. plugged in new harness and routed it just under the front seat mounting piece. used Velcro to secure the af-xied controllers just past battery and metal cross brace to top of inner fender. about an hour start to finish. after looking at it didn't think pics would be necessary.
    Dec 2007
    SE Alberta
    Did download any operating data prior and post to the install that could be analyzed and graphed as Roger hasnít done in the past?
  1. O2 Sensor Connector
    By bobr9 in forum Oilheads
    Last Post: 05-10-2014, 04:22 PM
  2. O2 Sensor Connector
    Last Post: 04-28-2014, 12:27 PM
  3. Hall Sensor Connector
    By happy wanderer in forum Airheads
    Last Post: 06-25-2013, 04:20 AM
  4. 92 K75RT mystery sensor/connector?
    By scoobs in forum Flying Brick K-bikes
    Last Post: 04-18-2013, 11:45 PM
  5. Hall Sensor Connector
    By Slablog in forum Oilheads
    Last Post: 04-06-2009, 02:58 PM
