Results 1 to 4 of 4
Thread: K75 Valve lash
    Nick Kennedy
    Telluride Colorado
    K75 Valve lash
    Hi Gents
    Over a long period of time do the valve gaps tend to open up or tighten up?
    I mean like over 40k or so miles.
    And is it different for the intake and exhaust?
    Thanks in advance!
    On K75s the valve settings are very stable. My '86 took one shim at 600 miles and not another until 60,000. Then one about 100,000 and one at 200,000 or so. When the bike died in a crash at 369,000 it still had one original shim from the factory.
    One reason is offsetting wear. As valve seats and valve heads wear the gaps will close. But as cam lobes and shims wear the gaps will open. Eventually, usually at very high mileage valve head wear overcomes other types and a valve job is needed. The ones I know about happened with 400,000 or more miles.
    Nick Kennedy
    Telluride Colorado
    Paul
    Thanks for the response
    My 1990 K75RT valves seem to be very stable over the last 30,000 miles.
    All were perfect at the last check.
    Very slightly tight on the intakes, .001 and very slightly loose on the exhausts .001
    Mar 2013
    Winnipeg, MB, Canada
    Rules: If valves tighten up, your are doing a valve job because the valve is either stretched or the seat is worn.
    If the valves are loose, you are looking at worn camshaft followers as you won't see worn lobes at valve adjust. Sometimes it's worn rockers.
    But, my buddy has another 20K miles on his K75 since I first found a slightly tight exhaust valve and three seasons later, it remains slightly tight.
    No worries there.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
  1. Valve Lash
    By snooser in forum Hexheads/Camheads
    Last Post: 10-08-2014, 11:38 PM
  2. Lentini Valve Lash
    By Walking Eagle in forum Oilheads
    Last Post: 05-03-2011, 01:01 AM
  3. Now that I've set my valve lash...
    By bostonmish in forum Airheads
    Last Post: 09-10-2010, 02:59 AM
  4. Try Valve Lash Increase for R1200?
    By evoneuw in forum Hexheads/Camheads
    Last Post: 09-08-2009, 10:19 AM
  5. Let's talk valve lash
    By leadfoot in forum Hexheads/Camheads
    Last Post: 12-23-2008, 05:01 PM
