Results 1 to 15 of 16
Thread: Where is the post? 2003 KGT rear shock replacement question
    Registered User CA1200's Avatar
    Aug 2003
    CO
    Question Where is the post? 2003 KGT rear shock replacement question
    2003 KGT
    I have been searching for the post where a guy replaced his rear shock with a Wilbers and he listed a step by step. If you know the title or where it is, please let me know.
    My bike has 35k on it now and I feel that the rear is soft even with the adjuster all the way engaged. Yes, I do run bags weighting about 20 lbs each.
    JC
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Didn't see it in the K Bike DIY and didn't have any luck with a search.
    I did it a few times on our 03 K1200RSs and I member it being fairly straight forward.
    Seems like it was a tight fit to get the adjuster routed past the fender.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    Gunsmoke has some instructions with pictures.
    http://www.gunsmoke.com/motorcycling...s/ohlins2.html
    I printed out my K1200RS shop manual.
    If you want it for the cost of mailing send me a PM.
    Lee
    2016 R1200RS
    MOA # 30878
    Liaison 20774's Avatar
    JC -
    I've done some searching as well and can't seem to find anything. You've posted this in the Flying Brick K-bike forum area. Is the bike a "Brick" or is it a Wedge-K bike? I'm not that familiar with all the variations. What is the model in question...K1200GT, K1300GT, or??
    Aug 2003
    CO
    horizontal 4 cyl - called a 'brick'
    JC -
    I was told long ago that a horizontal 4 cyl is called a 'brick'. So that is where I have been looking
    JC
    May 2003
    SW Iowa
    JC -
    The 03 K1200GT is a Brick. It's very similar to the 03 K1200RS.
    Lee
    2016 R1200RS
    MOA # 30878
    Thanks...as I said, I have troubles with these differences. I see on the main forum that we've identified the Wedge-K bikes starting in 2005.
    May 2003
    SW Iowa
    Yep, it's very easy to get the two K1200GT bikes confused.
    Lee
    2016 R1200RS
    MOA # 30878
    That said, I can't seem to find anything for the K1200GT that has a specific reference to step-by-step of a Wilbers shock on our forum. Could be that it was posted on ADV??
    May 2003
    SW Iowa
    Might have been on the old i-BMW site. That was a forum started for the K1200RS and had a ton of technical info.
    Lee
    2016 R1200RS
    MOA # 30878
    Aug 2003
    CO
    KGT rear shock removal proceedures
    The post was on this web. There were questions about room for the remote res's (1 or 2 depending on what you bought) Perhaps having to remove the charcoal canister to make room.
    I also question if the bike will collapse or using the center stand is enough.
    JC
    Here's the K-Bike tech articles on IBMWR...I don't see a specific article:
    https://ibmwr.org/index.php/k-bike-tech-articles/
    Aug 2003
    CO
    service cataloge
    This is cool any way. Thanks
    JC
    Aug 2003
    CO
    To much movement = tired shock?
    Let me take this time to expand on why I think the stock shock is tired.
    Like I said previously, I have the preload turned up all the way. Why? because I would bottom out our dips at speed. I also noticed a bit of pogoing on sweepers at speed. What speed? Well the dips I would say 80 mph. On the sweepers , 60-80. Otherwise, it is a nice soft ride and no complaints.
    Oh, BTY, I have a stock front shock also, but with an after market stabilizer.
    JC
    May 2003
    SW Iowa
    Quote Originally Posted by CA1200 View Post
    I thinks I was replacing our rear shocks at 30,000 to 40,000 miles.
    I would get a hinge in the middle of the bike feeling in fast sweepers.
    Our bikes had around 90,000 miles when we traded them and they still had the original front shocks.
    The fronts probably needed replacing but I could never feel a problem with the front.
    If I had changed the front I probably would have felt the improvement
    Lee
    2016 R1200RS
    MOA # 30878
  1. 2003 K1200GT - Any tips on the preload rear shock setting?
    By jrmull in forum Flying Brick K-bikes
    Last Post: 02-23-2019, 06:54 AM
  2. Replies: 8
    Last Post: 07-22-2017, 03:50 PM
  3. '10 K1300GT rear shock replacement
    By nschmutte in forum Wedge K-bikes
    Last Post: 07-29-2015, 02:16 AM
  4. Replacement rear shock ?
    By 40427 in forum Airheads
    Last Post: 05-25-2012, 08:19 PM
  5. K rear shock replacement
    By pmdave in forum Flying Brick K-bikes
    Last Post: 12-13-2003, 12:51 PM
