I've replaced both side foot pegs on the F/GS without a problem, but this Adventure model is designed differently. Engine side case interferes with moving shift lever high enough to get foot peg bolt all the way out...without apparent removal of entire shift lever.
Has anyone replaced foot pegs or shift lever on the F850GSA? The lever pivots on a very large torx nut/bolt. Is that pivot nut/bolt only attached to the mounting plate or does it run through and support more than the plate? Is it screwed into a fixed fastener or is there a back side bolt I'd have to get at? Appreciate any input.
