Results 1 to 12 of 12
Thread: ticking noise
    The Blue Max 31310's Avatar
    Calgary Alberta
    ticking noise
    Bike has developed a ticking noise but only on left side head the last few weeks, sounds like loose valves. Valves were fine but reset them anyway 200 kms ago, rocker arm end play within limits. Putting bike up for winter layup this aft, changed oil, no particles on magnetic drain plug, runs fine but the noise is concerning. Now at 168000 kms, bike has always run great, regular oil changes. Have my suspicions but would like feedback if possible. Thanks, Gary.
    2007 R1200RT
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    Cam chain tensioner?
    '13 R1200RT 90th Anniversary Edition
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Cool
    Quote Originally Posted by 31310 View Post
    Recheck the valve clearances....when really cold...you might, for kicks and giggles, check the cam chain for problems...doubt it would have any though...cam chain tensioner would not make "ticking" sounds unless there was a damaged link...
    ~wyman~
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
    Nov 2017
    Collierville, TN
    Mine occasionally makes a once-per-rev tick right at startup on the left side for a couple of seconds then goes away. I assume this is the tensioner pressurising which is why I suggested it. I really have no idea though so if I'm wrong I'd be happy to entertain other causes.
    Kawa Afterthought weschmann's Avatar
    May 2012
    DeSoto MO
    Quote Originally Posted by pappy35 View Post
    I just turn my hearing aids off and donít hear a thing,👂😉
    Nov 2017
    Collierville, TN
    Quote Originally Posted by weschmann View Post
    I just ride with these guys behind me. Works for me!
    Registered User bigjohn72's Avatar
    Feb 2015
    Haskell, Arkansas
    replace the cam chain tensioner if you have not already. I replaced mine with an aftermarket one for both sides, and its not hard to do. The OEM tensioners have pretty weak builds and tend to wear out quick. If the ticking goes away after it warms up, its a big sign they need to be changed, and the left one goes out first because of how its positioned on the engine, I forget the particulars. Look it up on youtube...
    Big John in Arkansas
    2014 K1600 GTL
    2007 R1200GS Adventure (Sold)
    MOA# 200130
    Calgary Alberta
    Thanks for the replies, among my guesses was the tensioner chain. Noise does not go away after warming up though. A winter project for sure.
    2007 R1200RT
    Registered User AjaxTheDog's Avatar
    Jun 2013
    Highlands Ranch, CO
    Not to be a bit picker but it's the tensioner, which is a plunger cylinder type thing with a spring in it that gets tired. I thought I had a bad bearing until I replaced mine. The whole tensioner can be had from Euro Moto electric for something around $75, or just the spring for under $10. These guys find the source manufacturers for BMW and buy the same parts from them, so it's OEM quality. I'd also recommend a new gasket crush ring as these leak easily, mine did. Also a flat spanner type ratcheting wrench helps as space is tight. The difference between my old and new spring was very small but the result was night and day, no noisy startup! I suggest you call these guys if you have any doubts, they know their stuff.
    https://www.euromotoelectrics.com/pr...-spring584.htm
    Bill in Highlands Ranch, CO
    2012 R1200RT
    There are many video's out there addressing this but this video is better than most imho. It's an 1150 but you'll get the gist.
    Calgary Alberta
    Thanks again for more replies guys. Great we can help each other so easily.
    2007 R1200RT
    Jan 2012
    niagara region
    Me tick too
    My Best bike ever 2006 gsa with 187000Km has the same ticking most herd when rolling at low speed and just lightly off throttle, noise is from right cylinder bank. After seeing the the fellow working on the same problem with his 1150 it made total sense to me. The parts micro fiche shows the up graded push rod, that being said i did replace the cam chain tentioner's which needed to be replaced thinking that the ticking was from that area but not.
    Peter
  1. BMW S1000rr ticking ???
    By eugene06 in forum S1000 - The Hothead
    Last Post: 09-29-2019, 07:33 PM
  2. Replies: 13
    Last Post: 11-26-2015, 05:19 PM
  3. metal ticking noise on the new 1200 GS
    By bullfrog_28560 in forum Wetheads
    Last Post: 03-01-2014, 09:18 PM
  4. Ticking sound
    By acrotwo in forum Oilheads
    Last Post: 09-15-2010, 02:25 AM
  5. 1992 R100GS, Ticking Noise? Not valves.
    By dougfollett in forum Airheads
    Last Post: 09-06-2010, 02:43 AM
