Results 1 to 6 of 6
Thread: 1972 r75/5 rear drive
    Mar 2019
    San Francisco
    I have a /5 with a 32/10 rear drive with a well worn spline
    I have access to a 37/11 rear drive with very low miles
    What would be the down side of using the 37/11
    I am assuming the speedo would be off somewhat and the rpms would increase
    Any pros
    Liaison 20774's Avatar
    Reduced gas mileage. Possible reduced top end speed. Quicker acceleration off the line.
    13278
    Apr 2006
    Near Lynchburg, VA
    Get the 37/11. If it is in good shape.
    Use until you get the 32\10 refurbished. You can ride right thru repairs.
    Rear Ends are hard to buy if non are for sale at a time when you need one.
    You shouldn’t be that dissatisfied with the difference between a 3.2 (32/10) and the 3.36 (37/11).
    Lower First gear (all gears) and lower 5500rpm highway speed (among other differences already mentioned). Lower speeding tickets too.
    Charlie
    Mar 2019
    San Francisco
    Thanks all for the help
    Any suggestions for the spline work
    West coastish
    Hansen's BMW in Oregon is the place most often brought up for repair work. Additional discussion about spline work locations was in this past thread:
    https://forums.bmwmoa.org/showthread...-spline-repair
    Rally Rat 1074's Avatar
    Sep 2004
    Las Vegas, NV
    You never know exactly what you get when you buy a used item. Since you know what you have now, I'd send your unit out for a re-spline and reseal. Then it'll be like starting from scratch. Hansen's is known for their good work and you'll get yours back as good as new!
    Boxerbruce
  1. 1972 BMW R75/5 - Rear Drive Shaft Boot Shavings?
    By b25bsaboy in forum Airheads
    Last Post: 09-21-2018, 01:51 AM
  2. k75 rear drive
    By drrider2 in forum Flying Brick K-bikes
    Last Post: 09-12-2003, 04:16 PM
  3. k11 k12 rear drive
    By eric2 in forum Flying Brick K-bikes
    Last Post: 09-06-2003, 02:59 AM
