cavedweller22
Howdy All Oilheads,
Ok, I have an 04 1150 RT that got me home a couple months back.. but just on a wing & a prayer.
Here is what I found, both main plugs were toast (little over 2K miles). I did discover the HES had the disintegrating insulation issue. Put in new
HES (due to time restrictions working on bike has taken awhile).
I only use non-ethanol fuel. New plugs, new coils on main plugs, new starter, new battery. Presently I have all 4 plugs out, bike turns over, appears good spark all 4 plugs.
But, even though I hear fuel pump, no fuel appears to be entering cylinders.
I have turned on key (no choke) 2 times throttle full, turned off bike.
What am I missing? Is it possible the Motronic has an issue? Or am I dealing with a fuel pump & or fuel filter issue?
Thank you for any possible suggestions.
