Results 1 to 15 of 18
Thread: Best adhesive for rubber tank panels , 22l tank - 1975 R90/6?
    Airhead
    Aug 2010
    Scottsdale, AZ
    I have had the 22 liter tank for my 1975 R90/6 repainted and pinstriped, and have procured new rubber knee pads.
    What is the best adhesive or two sided adhesive sheet to use to attach these?
    Thank you.
    Liaison 20774's Avatar
    Here's a couple of past threads on this:
    https://forums.bmwmoa.org/showthread...pads-on-5-tank
    https://forums.bmwmoa.org/showthread...-Tank-Question
    https://forums.bmwmoa.org/showthread...eepad-adhesive
    I've used the 3M Super Weather Strip Adhesive to glue the engine badges back on to my /7 engine.
    I love 3M weather strip adhesive for small items. But I am not sure I would like it for this application because it takes several minutes to set enough to hold things. Thus if I can weight the item or tape the item firmly in place I like it. If not then not so much. I think this is a place I would prefer a simple contact cement. The issue there though is you have to be precise when placing the panel because the contact cement grips instantly and no sliding into position is allowed. Good luck.
    Jan 2017
    Grandville Mi
    I used 3M Window Weld. It’s a urethane caulk used for installing windshields. I put a dot on each of the squares, and a very small bead around the perimeter, except at the very bottom. I left a small gap so any water that got behind the pad can escape. Before I glued on, I ran the pads through the dishwasher twice. Worked really well to remove the release agent from the pads. When in direct contact with the sun, my pads never distort, always stay flat. About $30.00 a tube, and hardly any gets used, but it is a permanent fix.
    Airhead
    Aug 2010
    Scottsdale, AZ
    Quote Originally Posted by drost View Post
    This sounds like the way to go. Thank you.
    Three questions:
    1 - did you use the primer (3M 08682)?
    2 - what dishwasher temperature did you use?
    3 - what did you use for a nozzle/gun as the 3M Window Weld comes with neither.
    Jan 2017
    Grandville Mi
    I used no primer. Just made sure tank was clean.
    Heat is your friend in the dishwasher, we use Cascade detergent in ours. I ran mine through twice.
    My caulk came with a nozzle, and used a good caulk gun, not the ratchet type. Purchased caulk at a independent auto parts store that sells to a lot of body shops.
    Start small when cutting the nozzle, and practice on scrap material. Can always make the opening larger, and there is way more in a tube than you will need. I think I used about an 1/8” bead around the center of perimeter. You do not want it oozing out, caulk does not just wipe off.
    Common sense and patience goes a long ways.
    Hope all goes well!
    Airhead
    Aug 2010
    Scottsdale, AZ
    Talking Found - a German sense of humor?
    Thank you.
    Also, why did the factory make those whorl-like indentations where the knee pads are attached?
    At first I though this might be the manifestation of a German sense of humor, but quickly discounted that foolish notion:
    Apr 2013
    Southern California USA
    Quote Originally Posted by THOMASPIN View Post
    Thank you.
    Mucho nice repaint and pinstriping job. Local guy? Do you know what paint was used?
    Registered User beemeruss's Avatar
    Jun 2007
    Edmonton AB Canada
    Thank you.
    [/ATTACH]
    Could they be for storing spare Bratwurst? Seriously though, I believe that they are stiffening ribs located in the hidden spot. The sides of the tank are the largest and least curved surface and that would prevent their flexing on a hot day with high fuel vapour pressure. That sure is some gorgeous paint and pins.
    Russ
    Airmarshal-IL James.A's Avatar
    Sep 2013
    central Illinois
    3M plastic and emblem adhesive, number on the box is 08061. It's also the best for the engine badges on the starter cover.
    1973 R75/5
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    [QUOTE=PGlaves;1184909]I love 3M weather strip adhesive for small items. But I am not sure I would like it for this application because it takes several minutes to set enough to hold things. Thus if I can weight the item or tape the item firmly in place I like it. If not then not so much. I think this is a place I would prefer a simple contact cement. The issue there though is you have to be precise when placing the panel because the contact cement grips instantly and no sliding into position is allowed. Good luck.[/QUOTE
    Use wax paper for keeping "instant" adhesives from bonding together. The adhesives do not become attracted nor attached to the wax paper. One slips the wax paper in place between the two, align them properly, slide the paper out a bit to begin attaching, and then finish the job.....Works great on this, furniture veneers, or counter-tops...……….God bless.....Dennis
    [QUOTE=DennisDarrow;1185080]
    Thanks Dennis.
    Airhead
    Aug 2010
    Scottsdale, AZ
    The knee pads are handed, thus:
    Left: 12300482R
    Right: 12300482L
    Interestingly, the MaxBMW fiche lists only one part number (16 11 1 232 235) but mine arrived as above.
    The purpose of the raised squares defeats me. Fewer than half of them will be in contact with the tank's sides, owing to the 'bratwursts'.
    Thus, unless you care to figure out which ones will be in contact, the optimal glue application strategy would appear to be to apply a layer around the periphery of the pad (avoiding getting too close to the edges in case of squeeze-out) then apply additional glue to the surface of the tank where it is not indented.
    The work was done by Spooky Fast Customs, a local Scottsdale, AZ place which does custom bike work and high end corporate furniture. They sub-contracted out the relining of the interior which I wanted done as it was flaking, and flakes of old paint in the carbs are likely not a winning strategy. The lining finish is gloss smooth and orange/red:
    They told me that most of the cost was incurred on the relining but did not know the process well enough to explain it to me.
    I do not know the maker of the paint, but the reputation of this shop is so high I simply trusted them to do the right thing. All I asked for was 'Avus Black'.
    I was offered the option of stick-on stripes. After a suitable stream of invective made it clear to the salesman that the ladies in Berlin did the originals by hand, I explained that I expected no less. The charming imperfections in the hand pin-striping are very much like the ones on my original 18 liter tank. Simply stated they announce: "Done by hand".
    Apr 2013
    Looks to be first rate job and I guess the liner is ethanol resistant too.
    I think the squares on the back side is to give the excess adhesive a place to go, like the flutes on dowels for joints in woodworking, My best guess at least, Cheers.
    Airhead
    Aug 2010
    Scottsdale, AZ
    Job completed
    Here's the installation process.
    As I had to take out a second mortgage to pay for the repaint etc., I took special care not to mess this up.
    3M masking tape is applied with each piece marked with a thin straight line. The tape is then cut with a sharp blade at the pad periphery, taking care not to damage the painted surface underneath:
    The 3M adhesive tube is installed in a caulk gun. The provided nozzle is already open at the business end. Old pad shown:
    I did the work indoors, 77F, at which temperature the adhesive has 50lb shear resistance after 4 hours and is fully cured (250 lbs) in 24 hours. 3M has an excellent technical sheet on the web. The working time is 10 minutes, allowing a little 'wiggle room'.
    I did a test run of how much to apply to avoid squeeze out, using one of the old pads and a sheet of aluminum:
    Perfect for the circumference.
    After going through two hot dishwasher cycles to remove all traces of mold release agent, both the pad and painted tank surface are cleaned with isopropyl alcohol (91%) before applying the circumferential adhesive bead to the pad:
    The wobbles are not the result of the DTs; the trigger on the caulk gun is quite stiff owing to the high viscosity of the adhesive. When the pad is positioned for placement, it's a simple matter of aligning the index marks scribed on the masking tape for perfect alignment.
    Before the pad is emplaced, the non-bratwurst surfaces are generously coated with adhesive, avoiding the depressions and the periphery. Glue inside the brats serves no purpose:
    The parts awaiting replacement - a 24mm wrench is required to remove and replace the petcocks. The mesh stockings have their own crush filters so no fiber washer is required. The correct period petcocks are straight through, not right-angled like mine, but these work fine. The crush washers on the socks were in good shape, so I reused the socks:
    The fuel filler cap is attached by a rod which is serrated on the left hand side. It is removed and replaced from the left as you sit astride the bike, using a small punch and hammer:
    The new roundels are self-adhesive:
    Here's my machine with the 18 liter tank, as shipped from the factory in 1975, original finish except for the roundels:
    And here it is now, in my 30th year of ownership:
    The 22 liter capacity, or 5.8 gallons, computes to a 250 mile range at my average of 43mpg.
    Many thanks for all your suggestions, with special thanks to 'drost' for the dishwasher and glue tips.
  1. Where can i find the side tank panels for sale (2005 R1200GS)
    By STANTONBARBAS in forum Hexheads/Camheads
    Last Post: 05-14-2013, 01:05 PM
  2. Toaster Tank Chrome Panels
    By Fleadip in forum Airheads
    Last Post: 02-02-2013, 01:46 PM
  3. Remove Adhesive Residue from Tank - 07 GSA
    By ihint in forum Hexheads/Camheads
    Last Post: 03-22-2012, 02:07 AM
  4. 1200 Silver GSA Tank Panels
    By mobe1957 in forum Oilheads
    Last Post: 03-30-2007, 05:27 AM
